Reverse 3PH Snowblowing: Creeper or Shuttle?
/ Reverse 3PH Snowblowing: Creeper or Shuttle? #1
Smalljobs
Massachusetts
Jinma 284
I've read most of the threads on snow removal and also the general thread for creeper versus shuttle. Since I'm planning to purchase a 254LE soon, I want to make the best decision but I can't seem to find much first hand user experience on which transmission will best suit my needs for the snowblowing application. Any advice on this will be appreciated.
/ Reverse 3PH Snowblowing: Creeper or Shuttle? #2
I have a 2006 284 with creeper and can tell you that the creeper range in reverse is virtually useless for snow blowing. Further, I can also tell you that the hi range reverse is much too fast for blowing and the low range reverse is a might too slow (but the only practical gear to use). I cannot comment on the shuttle but it seems logical that it would be better. I have blown a lot of snow in that gear:eek:
Regards
/ Reverse 3PH Snowblowing: Creeper or Shuttle? #3
I run a rear blower with a geared tranny.
Hi reverse is much too fast for any snows that need blowing.
Low is fine for the 4-10 inch falls depending on density of the snow.
Usually when snowfalls are in the 6-12 debth I find that I want to make less than full passes in order to keep RPM's up
All that being said I sure wish I had a creeper gear, especially when cutting back snow banks, while slower I could take full passes and get it done with.
Entrance ways filled by the city plow would be a snap with creeper gear.
If not a $$ extra, I'd suggest you take it.(or upgrade to hydrostatic)
/ Reverse 3PH Snowblowing: Creeper or Shuttle? #4
The beauty of a shuttle transmission is that for every forward gear choice, there is a reverse choice. True whether we are talking about a manual shuttle, hydraulic shuttle of whatever name, or a powershift with a reverser. Snowblowing in reverse is all about speed/gearing choices; the more you have, the better the chances you will find a reverse speed that matches your conditions and comfort level.
2022 Mack Pinnacle T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Mack Pinnacle...
2003 MAC TRAILERS 45' WALKING BOTTOM TRAILER (A60430)
2003 MAC TRAILERS...
2021 CATERPILLAR 279D3 SKID STEER (A62129)
2021 CATERPILLAR...
2025 48in. Farm Jack (A61567)
2025 48in. Farm...
2018 GENIE GS-1930 ELECTRIC SCISSOR LIFT (A62129)
2018 GENIE GS-1930...
Bobcat S740 (A57148)
