If the wheel nut has a flat washer made to slip then I use the gear oil on that.
On a class eight the new style is a nut with a captive washer, and you are suppose to lube the washer to nut section so the washer does not turn on the rim,
On a lot of aluminum auto rims they use a washer I lube them between the nut and washer also.
If you look at a rim and it has a rust streak spokeing away from the studs that wheel is loose.
You don't put any on the shoulders of the nut then Scotty?
Kind Regards, Mike
If we are talking about the same thing, my F250 has a spin washer on the lug nuts. The owner's manual advises putting one drop of 30W oil on the washer only when remounting and torquing in sequence.
In a word: "No"! But in listening to others, I want to say that all of my applications have been with "cone" nuts, (on Cars/trucks) and "Cone" bolts, on my Boats trailers, etc. I just moderately treat the threads. ~Scotty
PS- I don't think I've ever seen a 'spinning' washer on a wheel-mount fastener. ~S
I can see where torquing a steel cone nut repeatedy, into an Aluminun rim, could result in [rim] metal loss. Guess I've been fortunate not to have to change tires enough that it's been an issue........ ~S
I have one good "click off" type torque wrench that only measures up to 80 ft/lb.
I also have an old style 1 ft long pointer bar type wrench which measures to100ft lb.
The torque setting for my tractor front wheel nuts is 120 ft/lb and the rear wheel nuts are about 240 ft /lb
Up until now, I have had to improvise to get an approximate torque setting
I use a 1 ft long 1/2" swivel drive breaker bar and a little more force than I would normally use to get to 100ft/lb on my pointer torque wrench, to get my 120ft /lb.
For the rear nuts I figured that if I use a breaker bar twice as long (2ft) with the same force I should be getting around 240 ft/lb.
Does this seem reasonable to those more knowledgeable?
I also decided, after reading this enlightening thread, to have another look at some torque wrenches in the auto store.
While inspecting the different ratings of the wrenches , a couple of things puzzled me.
The store was selling a 1//4 " drive, one ft long torque wrench that claimed to measure from 40 up to 250ft /lb.
On a different rack was a 1/2" drive two ft long torque wrench that would only measure up to 150 ft/lb
It seems to me that it might be difficult for an average man to have the strength to achieve 250ft lb with a one ft long bar.
Similarly, can any single torque wrench accurately measure a torque range from 40ft/lb to 250ft/lb
I guess the 1/4" drive measured in pound inches (lb/ins) Dennis.
Guessing your torque with a breaker bar is a pretty iffy business.
Kind Regards, Mike
I know this is all estimation but I am only checking the tightness of the nuts (every 50hrs) not setting the torque
When my mechanic swapped rear wheels, for widening, at my free 50hr home service he used a breaker bar to re tighten the nuts.
This is when I decided to also use this method.
You should consider torque striping the nuts.
Pretty simple thing to do...
Use a paint marker (color should contrast with the threads, nut and adjacent wheel surface).
Just mark a line (as straight as possible...use a straightedge if you can) from the stud thread, across the nut then on to the wheel.
If the nut comes loose, the painted lines would not be aligned. Makes for a very simple visual examination of the wheel nuts (or bolts, if the tractor uses bolts).
There's no doubt a paint line is a good system Roy. What do you reckon to those pointy things that sit on the wheel nuts and tell the story from the 25 yard line please?Use a paint marker (color should contrast with the threads, nut and adjacent wheel surface).
I would then guess that the maximum torque I could get with a one foot breaker bar would be about 120 ft lb and likewise 240 ft lb from a two foot bar.
As mentioned, I have checked my wheel and loader nuts regularly, with the breaker bars, since purchase 210 hrs ago. They got a little loose in the first 10 hrs but since then nothing much.
