Retaining Wall Failure
   / Retaining Wall Failure #41
I'm a retired supervising civil engineer and I have a few thoughts about hiring a contractor. The normal method is to hire the low bidder but the european method is a better way to be sure of getting it done right. Depending on the number of bidders of course, throw out the highest and lowest bids, average the ones that are left and go with the one closest to the average. This pretty well assures you that the job will be done right (but have an inspector on hand as much as possible) for a price that is fair. Remember that a contractor is entitled to a profit and if he is good, you want him to stay in business to do your NEXT project! Low bidding invites shortcuts.
Accepting bids on the European averaging method is just good business. I do that for all my own jobs and also for municipal jobs where I can.
When the job bids come in, I've found that the town council is always willing to go with averaging the bids when the process is explained to them.
rScotty
   / Retaining Wall Failure #42
Failures like that aren't really much about the way that the blocks of the wall are assembled together.
Keeping it from failing is partly about the shear strength of the soil beneath the bottom of the wall, and more importantly removing any water from behind the wall.
Pay attention to those things first, and the chances it will stand for a long time go way up.
rScotty
   / Retaining Wall Failure #43
I can't tell, but looks a little like the layers are not recessed to the rear enough. prevent the back to lock. I see what looks like a rebar pins, but not with every row. I am also not sure the dirt (mud now) is sufficient to hold. Probably should be more recessed, pinned and backfilled with rock.
   / Retaining Wall Failure #44
Had a customer call for help this past year. Found this
Wall is about 12’ high. That is their garage that they had built/attached to the house above.
Cost for this wall and another built by the same contractor was about half of what I would’ve expected….there’s the answer as to why.
This is outside my scope of work, so I passed. I’m not a wall guy but I have some knowledge, zero drainage, zero geogrid, not enough rock behind. No engineer involved.
Any weight placed above the wall within a plane of 45 Degrees of the bottom of the wall is a surcharge. That garage places a huge surcharge on that wall. That particular wall is designed to fail!
   / Retaining Wall Failure #45
I am curious, is there a general rule for how close a building can be built to a retaining wall? Even if the wall would have been well built it seems that the building it too close to the wall.
Attached is a picture tall retaining wall close to Charlotte NC. The builder used this wall to develop land that was in a high traffic area and also in a ravine. The buildings were condemned at the time, I do not know their status today.View attachment 731979
I built walls in Charlotte. I can answer the question of "how close..." You can build the wall and building as close as the qualified engineer says you can build it, on an approved set of drawings, as long as you follow all the instructions he gives.
There is no acceptable rule of thumb!
Warning to many here. I see a lot of posts that have SOME knowledge. There is much more to this than the simple comments! A little bit of knowledge can be very dangerous!
   / Retaining Wall Failure #46
Thank you for response. After reading your post I found the link below.
It seems like if you are greater than 50 feet from a structure AND less than 5 feet of vertical relief there is not a requirement; otherwise one must: " Submit, as part of the permit drawing set, retaining wall drawings, fully designed and detailed, and sealed by a NC Licensed Professional Engineer"
"The 2006 North Carolina Building Code includes requirements for the design and construction of retaining walls. Specifically, section 1806.2 states: Retaining systems providing a cumulative vertical relief greater than five feet in height within a horizontal distance of 50 feet or less, including retaining walls or mechanically stabilized earth walls, shall be designed under the responsible charge of the registered design professional. Retaining systems shall meet the requirements of Section 1610. Testing and inspection reports shall comply with Section 1704.1.2"
   / Retaining Wall Failure #47
I don't know if there is a fix for that wall other than taking it all out and starting over. How that ever passed an inspection is beyond me. How they ever got a permit to build the garage without documentation, including permits and inspections, of the supporting wall is beyond me.
   / Retaining Wall Failure #48
Absolutely, I told her to start with an engineer and the wall along with the second one, should come down and start over, but her starting place needed to be an engineer.
If memory serves correct, the garage was built before the dig out, to create the flat area below the wall for a basement walk out and pool area. But no idea on permitting or inspections.
Like I stated I repeatedly told her that it was outside my scope and only shared observations, pushing that she needed to start with an engineer.
   / Retaining Wall Failure #49
Her contractor must have said something like, "Permits? Permits? We don't need no stinking permits."
   / Retaining Wall Failure #50
I worked in Charlotte for 20 years in residential before I started doing commercial work. Charlotte area soils are not good for most building, hence the number of foundation problems; I've seen entire stone facades fall off of a house. That bull tallow clay is tricky to build on, and no one does it right.
2022 Polaris Ranger Utility Cart (A55788)
2022 Polaris...
CFG Industrial MH12RX (A53316)
CFG Industrial...
2025 JMR 36in Mini Skid Steer Bucket (A55787)
2025 JMR 36in Mini...
WHISPERWATT 220 DIESEL POWERED GENERATOR (A55745)
WHISPERWATT 220...
Kivel Pallet Forks (A53316)
Kivel Pallet Forks...
2019 TerraGator 7300 Spinner truck (A55302)
2019 TerraGator...
