Restore ym 2210 problem
/ Restore ym 2210 problem #42
I can tell you similair gaskets on my 2002d have been about .026". I would use 1/32" material or similiar mm size and get on with it.
I have the gasket thick 1mm, is too high for this application? thanks
/ Restore ym 2210 problem #44
I will ramble a little here. The differential carrier bearings install in the axle housing. They have shims behind them on both sides. The bevel gear to pinion gear should have about .006" to .009" backlash. That is accomplished by proper shim size on both sides. The proper thickness axle housing gasket also plays a roll. The thicker the gasket the more you will affect backlash.
Was there not a piece of the old gasket you could check for thickness?
New parts arrived today from Hoye, i would like to thanks Aaron and your team for very fast shipment! i'm very happy :drink:
Olaaaa, new pics
WP_20150216_010.jpg new head, valves, springs, seals
/ Restore ym 2210 problem #52
Very nice primer work.
Molto bello il lavoro di primer.
Massey-Ferguson red and white colors for the body panels.
Massey-Ferguson colori rosso e bianco per i pannelli di corpo.
The chassis color is light green or teal.
Il colore del telaio è verde chiaro o verde acqua.
YM2210 Restaurato. Clicca sull'immagine
Yanmar Ym2210, 2wd, 26hp, Decatur AL - 112151961 - EquipmentTraderOnline.com
/ Restore ym 2210 problem #53
he should of got the paint if from them before he ordered...another box to itily will be xostly
Thanks, about the red i have found two massey ferguson red, super red for vintage tractor (mf 35) and red for actual tractor, which is the correct color? thanks :thumbsup:
/ Restore ym 2210 problem #55
might call hoye and see? or try and wait Aaron out here, or send him a pm on the site here?
/ Restore ym 2210 problem #56
Thanks:thumbsup:
/ Restore ym 2210 problem #58
Neither is correct, both are close. Hoye color-matched their own mix, I think from the lower dash panel.
/ Restore ym 2210 problem #59
Seeing that he is doing a restore in Italy, it would be cost effect with the M-F colors being a very close match. He can buy what is local than to order, pay the shipping and export/export taxes before it arrives to his door.
Obtaining the colors locally keeps costs down and he has availability for years to come. His Yanmar would look new vs. most looking shabby over there. Thus, the comparison would be minimal to the faded paint and rusty gray market Yanmars already out there in Italy.
/ Restore ym 2210 problem #60
i am with you. Yes it may not be right but no one but a purist would know and most could never tell unless it was side by side with the correct color. I would find what i can get local that is close and use it and not loose sleep over it before i shipped it international. The shipping on a flat rate Internation 12x12x6" box is like $60 if i remember right.
2021 CAT 289D3 (A60462)
2021 CAT 289D3...
2016 Ford F-150 Ext. Cab Pickup Truck (A61573)
2016 Ford F-150...
2019 Dodge Durango SUV (A61574)
2019 Dodge Durango...
UNUSED WOLVERINE HYD TILLER (A64281)
UNUSED WOLVERINE...
2014 KENWORTH T370 ROAD TRACTOR (A64280)
2014 KENWORTH T370...
2019 ISUZU NPR 4X2 S/A 20FT BOX TRUCK (A59912)
2019 ISUZU NPR 4X2...
