BravoXray
Elite Member
- Joined
- Dec 17, 2019
- Messages
- 3,410
- Location
- Nothern Indiana
- Tractor
- Kubota BX2230, John Deere 430 Diesel
Well, the engine is out, again. Hopefully the last time.
I worked on Wednesday and Thursday getting everything disconnected, I have it down to a science now. One of the hardest things is getting all the cable ties cut off the wiring harnesses, I use a lot of them to keep things neat and away from hot or moving things.
I had Brian stop on his way home from work and help me get the hood off again. He couldn't believe the block was cracked and that I had to pull the engine again.
Pulled it out, got the trans off and hung it on the engine stand. Then, I methodically started removing parts, laying them out on tables, carts and benches. I pulled out the lifters and put them in a piece of 2X4 with holes drilled in it to keep them in the correct positions on the cam lobes. All the lifters and the cam lobes look good, so it was properly broken in. I got it down to where all that is left is to remove the rod/piston assemblies and the crankshaft. I will also remove the dowel pins that locate the bellhousing, because I'll have to go through the process of dialing in the crankshaft/input shaft runout on the new block.
Then there's just a lot of cleaning up, inspecting parts, checking for wear and measuring the pistons so the block can be bored to the correct dimensions. Thankfully, I have a big commercial size parts washer which helps a lot when doing a job like this.
Then, I just have to wait to get the new block.
