Tires Replacing Tires
/ Replacing Tires #11
You are correct on the tire rim. My current front rim is 14" and the turf tires would require a 12" rim. The rears are both 16". This tractor would be used just for grass cutting and maybe other work once in a while. I used to keep this tractor at my camp in the mountains in north central Pennsylvania. I used it for everything. Grass cutting, backhoe work and FEL work. It was well set up for the 20 years I used it there but I sold the place last Spring and now I have it at home where we have about two acres of grass to cut. My wife uses a BX1860 and I use the B2710 but the B2710 with R4's is hard on the lawn. That's why I am thinking of putting the turf tires on it.
I see you have 14" front rims and 16" rear rims, I don't see where you have posted your current tire size.
The original data that I saw was for R1's a 7x12 front which has a width of 6.8" and a diameter of 24", with a rear of 12.4x16 which was a 12.4 width and a 37.7" diameter.
If you go to the Miller Tire website, between the lawn and garden tire and compact tractor tire listing there are several 24" tall tires with 12 or 14" rims.
As far as the rears you could go here Tire Size Comparison scroll down to wheel size click on 16's then scroll to your desired diameter and look for truck tires, they will work quite well as turf tires.
/ Replacing Tires #12
for turf tires, you want as wide as possible, so you get as much traction as possible, WITHOUT sinking in, or making holes in the grass.. you don't always get a rain free, nor flat surface to mow..
/ Replacing Tires #13
I have never heard of Kubota Wholegoods. Is it a place where you can purchase items? Would someone give me a link to the site? Also, the rear tires are 16."
You can inquire with the sales department at any Kubota dealer, do not ask the parts department, you will get a much higher price.
Basically the wholegoods list is what the salesman looks at when putting a tractor together for pricing.
Sometimes a company will post up a wholegoods list from recent years so you can get an idea on price. Might have to find a newer model Kubota tractor that uses the same tire size/ lug pattern.
Looks like the current B2650 uses the same tire sizes as your B2710
2020 DRAGON ESP...
2022 Wacker Neuson PDT2A 2in Portable Diaphragm Pump (A55851)
2022 Wacker Neuson...
2016 MACK CXU613 MID-ROOF SLEEPER (A58214)
2016 MACK CXU613...
Toro Greensmaster 3150-Q Riding Mower (A56859)
Toro Greensmaster...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Volvo L306 (A57148)
Volvo L306 (A57148)
