bill18163
I have a Kubota B2710HSD that I bought in 2000. It came with R4 Ind. tires on it. I would like to replace the R4's with turf tires. The front tires are worn pretty bad but the rear tires look OK. I could just purchase the turf tires that are specified in my manual but I wanted to be sure that I maintained the correct front to rear ratio since there could be small differences from manufacturer to manufacturer in the tire size. Just wanted to be careful. I read a lot of the old posts on this forum on this subject. A lot of them were very helpful and I learned a lot which made me cautious about doing this. One of the things that I hunted for in the forums and ultimately all over the internet was the front axle gear ratio of my tractor. I came up with nothing. I could not find any information on this at all. I ran across a couple of calculators on line that would help with the tire selection but they required that gear ratio. I emailed Kubota tech people and asked the question. The person that replied to me said she could not find any info on that gear ratio. She suggested I use the info in my manual for the purchase of the tires or to go ask my dealer the question about the gear ratio. I didn't expect that kind of answer from Kubota. I went ahead and used the info from the manufacturer of the R4's currently on the tractor to get an idea of what circumference to use for the front and rear tires but I would still like to be more sure. I even looked up the gear pair in the front axle to see if I could calculate the ratio but that didn't pan out. There was a pair of numbers there (11/20) but that would generate a number of 1.82 which I don't think is right. Too high. So, has any one been able to determine this gear ratio number for a particular tractor or found a way to get the info? Years ago if I or my friends wanted to find the rear end gear ratio of a car we just put a chalk mark on the bottom side wall of the tire and another chalk mark on the drive shaft and drifted the car till we had one revolution of the tire while counting the revs of the drive shaft. Since we knew most of the rear end ratios of particular cars it wasn't hard to tell what you had. But if you did this with a tractor you would only have a ballpark number and I don't know if that would be useful. So I guess I'm back to asking if anyone has ever been able to get that gear ratio number from somewhere?
