replacing liners on my JD 2240
   / replacing liners on my JD 2240 #1
mark vetter
elma wa.
kubota L4350 jd2240 kubota 8540
I posted nearly 2 years ago on my problem losing water due to combustion gases entering radiator, then going out the overflow. Ive nursed it along but may do something before too long. My question is, if I drive the old liners out (inframe) and buy new piston/liner set, is there much chance of success sealing the new liners in a 40 year old block? Ive been told i must set it up in a boring mill, take a skin cut on the top face, then recut the counterbore for the liner and use a brass shim so the liner protrudes about .006 thou. Hope that makes sense. My goal is to do as little as possible but have a second string tractor for utility.
   / replacing liners on my JD 2240 #2
We still do the is here. Just make sure the gasket has enough place in contact with the block and sil head.
   / replacing liners on my JD 2240 #3
Just be sure to clean grooves in block that sealing rings fit into very well. Many in frame overhauls with new pistons/liners have been performed on JD engines over the years since the mid 60's.
many thanks
2021 CATERPILLAR 730 OFF ROAD DUMP TRUCK (A60429)
2021 CATERPILLAR...
2016 Ford Fusion SE Sedan (A59231)
2016 Ford Fusion...
Kubota L4701 (A53317)
iDrive TDS-2010H...
TANK MANIFOLD (A55745)
2015 Freightliner 122SD T/A Wet Kit Day Cab Truck Tractor (A59230)
2015 Freightliner...
