replacing liners on my JD 2240
   / replacing liners on my JD 2240 #1
mark vetter
elma wa.
kubota L4350 jd2240 kubota 8540
I posted nearly 2 years ago on my problem losing water due to combustion gases entering radiator, then going out the overflow. Ive nursed it along but may do something before too long. My question is, if I drive the old liners out (inframe) and buy new piston/liner set, is there much chance of success sealing the new liners in a 40 year old block? Ive been told i must set it up in a boring mill, take a skin cut on the top face, then recut the counterbore for the liner and use a brass shim so the liner protrudes about .006 thou. Hope that makes sense. My goal is to do as little as possible but have a second string tractor for utility.
   / replacing liners on my JD 2240 #2
We still do the is here. Just make sure the gasket has enough place in contact with the block and sil head.
   / replacing liners on my JD 2240 #3
Just be sure to clean grooves in block that sealing rings fit into very well. Many in frame overhauls with new pistons/liners have been performed on JD engines over the years since the mid 60's.
many thanks
2024 HURRICANE GF480 - 48" ROTARY DRUM SCREEN (A52706)
2024 HURRICANE...
406 (A52706)
406 (A52706)
2016 KOMATSU D65PX-18 BULL DOZER (A58214)
2016 KOMATSU...
2016 CATERPILLAR TH255C TELESCOPIC FORKLIFT (A60429)
2016 CATERPILLAR...
2007 John Deere 644J Articulated Wheel Loader (A59228)
2007 John Deere...
2019 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A60429)
2019 CATERPILLAR...
