Replacing gate with ramps.
/ Replacing gate with ramps. #1
plowking
Nottingham, N.H.
2009 MF 1531 TLB
I'm lookin' for some advice. I have a 16 foot PJ landscape trailer,the mesh gate has the tractor on too much of an incline and backhoe catches the ground going on trailer[ I've raised and angled the backhoe,it still drags,not as bad]. I've looked at gate extenders or aluminum ramps,the ramps are far away purchased online and shipping adds on more. The mesh gate should be stronger as a ramp,also I have to put machine all the way forward to close the gate. I had a subcompact, but got a compact and it uses the same trailer. Thanks,plowking
/ Replacing gate with ramps. #2
Replacing the mesh gate with ramps with reduce your drag, plenty!!...:D
/ Replacing gate with ramps. #3
I just built a set of ramps for my dump trailer.
They are 6' long, 3" channel with 2X2 angle for rungs.
They are heavy, orginally I was going to remove them each time, I rethought the plan and made them fixed to the trailer.
I painted them with aluminum paint, to try and lighten them, it did not seem to help, they are still heavy!
/ Replacing gate with ramps. #4
I like ramps vs gates... They are easy to weld up with hd angle iron and some rod...
soundguy
/ Replacing gate with ramps. #5
As a temporary fix for the dragging backhoe, you can strategically place some boards on the ground to be under the tires at the point where the backhoe would normally hit the ground. This should raise it up enough that it doesn't catch anymore.
Jeff
/ Replacing gate with ramps. #6
4 short sections of 4x4, 2 piece side by side under each tire may just do it.. we have done that in the past.
soundguy
2022 Blue Diamond Brush Cutter (A64126)
2022 Blue Diamond...
White Oak Slabs (A65640)
White Oak Slabs...
2022 EZ-GO ELITE...
10' Feed Bunk (A66408)
New 10' Cattle Working Chute (A62679)
New 10' Cattle...
Quick Attach Backing Plate (A65579)
Quick Attach...
