Replacement lights
/ Replacement lights #1
hardhat
One of the work lights on the back of my 5610 burned out. Replacement is $27 for the entire light assembly. All I need is a new bulb. Anyone know where to get these?
/ Replacement lights #2
If you can get the light open and bulb out, take it to an auto parts store and ask. It's usually a good idea NOT to touch the new bulb with your bare fingers because the oil will cause the bulb to burn out.
I can get the bulb out but it looks like it is soldered to the part that screws to the light housing.
/ Replacement lights #4
Never saw one like that - is there a number on the bulb base ? You might want to take the whole housing (with bulb) in to your dealer and ask. :confused:
Dealer found bulbs. Was the bulb and the part that screws into the housing. $12/ each. Will try to find way to replace just bulb and re use the screw in part, will just take a little soldering I think
1539 (A65054)
1539 (A65054)
2025 60 Gallon Poly Diesel Tank w/ 12v Pump, nose, Nozzle and Pump (A64556)
2025 60 Gallon...
Connect CH65 Hydraulic Breaker Excavator Attachment (A64194)
Connect CH65...
2024 SILVERBACK 53CH3A TRI/A CAR TRAILER (A67148)
2024 SILVERBACK...
2026 SDLANCH SDLMG1220F Galvanized Metal Livestock Shed (A64194)
2026 SDLANCH...
STIHL HT250 POLE SAW (A64276)
STIHL HT250 POLE...
