Replacement lights
/ Replacement lights #1
hardhat
One of the work lights on the back of my 5610 burned out. Replacement is $27 for the entire light assembly. All I need is a new bulb. Anyone know where to get these?
/ Replacement lights #2
If you can get the light open and bulb out, take it to an auto parts store and ask. It's usually a good idea NOT to touch the new bulb with your bare fingers because the oil will cause the bulb to burn out.
I can get the bulb out but it looks like it is soldered to the part that screws to the light housing.
/ Replacement lights #4
Never saw one like that - is there a number on the bulb base ? You might want to take the whole housing (with bulb) in to your dealer and ask. :confused:
Dealer found bulbs. Was the bulb and the part that screws into the housing. $12/ each. Will try to find way to replace just bulb and re use the screw in part, will just take a little soldering I think
2018 Tycrop Vector Belt 22ft. VB-16H Portable Sand Belt Conveyor (A64194)
2018 Tycrop Vector...
2006 INTERNAITONAL 7600 6X4 T/A DUMP TRUCK (A66091)
2006 INTERNAITONAL...
2009 8 Mil BTU Tri-Axle Hot Oil Trailer (A64194)
2009 8 Mil BTU...
2022 EZ-GO ELITE...
UNUSED RAYTREE RMLL60-60" HYD POWER RAKE (A65055)
UNUSED RAYTREE...
2017 ISUZU NRR 4X2 S/A STAKE BODY TRUCK (A67148)
2017 ISUZU NRR 4X2...
