Replacement lights
/ Replacement lights #1
hardhat
One of the work lights on the back of my 5610 burned out. Replacement is $27 for the entire light assembly. All I need is a new bulb. Anyone know where to get these?
/ Replacement lights #2
If you can get the light open and bulb out, take it to an auto parts store and ask. It's usually a good idea NOT to touch the new bulb with your bare fingers because the oil will cause the bulb to burn out.
I can get the bulb out but it looks like it is soldered to the part that screws to the light housing.
/ Replacement lights #4
Never saw one like that - is there a number on the bulb base ? You might want to take the whole housing (with bulb) in to your dealer and ask. :confused:
Dealer found bulbs. Was the bulb and the part that screws into the housing. $12/ each. Will try to find way to replace just bulb and re use the screw in part, will just take a little soldering I think
Engine knock
Engine knock
2010 RU SYSTEMS SMART 850 SIGN TRAILER (A66091)
2010 RU SYSTEMS...
UNUSED JCT-72" HYD TILLER (A65055)
UNUSED JCT-72" HYD...
2019 Westinghouse WSTBT1503 Wireless Speaker (A61574)
2019 Westinghouse...
2013 Toro Groundsmaster 3280D 72in. Commercial Riding Mower (A64194)
2013 Toro...
2001 Freightliner FL112 T/A 5 Car Hauler Truck (A64194)
2001 Freightliner...
