Replacement lights
/ Replacement lights #1
hardhat
One of the work lights on the back of my 5610 burned out. Replacement is $27 for the entire light assembly. All I need is a new bulb. Anyone know where to get these?
/ Replacement lights #2
If you can get the light open and bulb out, take it to an auto parts store and ask. It's usually a good idea NOT to touch the new bulb with your bare fingers because the oil will cause the bulb to burn out.
I can get the bulb out but it looks like it is soldered to the part that screws to the light housing.
/ Replacement lights #4
Never saw one like that - is there a number on the bulb base ? You might want to take the whole housing (with bulb) in to your dealer and ask. :confused:
Dealer found bulbs. Was the bulb and the part that screws into the housing. $12/ each. Will try to find way to replace just bulb and re use the screw in part, will just take a little soldering I think
Welcome to the Farm Metal Decorative Sign (A61569)
Welcome to the...
2022 BIGHORN EXPLORER 400 EFI UTV (A62130)
2022 BIGHORN...
(INOP) VOGELE VISION 5200-2 ASPHALT PAVER (A62130)
(INOP) VOGELE...
500 GALLON FUEL TANK (A62131)
500 GALLON FUEL...
UNUSED CFG INDUSTRIAL MX15RX MINI SKID STEER (A62130)
UNUSED CFG...
Vermeer 5400 Rebel Hay Baler (A61166)
Vermeer 5400 Rebel...
