Replacement Directional Control Valve
/ Replacement Directional Control Valve #21
If the recommended torque is 32 ft lbs, I think I would tighten them to 32 ft lbs.
If the pressure causes the o-rings to extrude, you will need new o-rings in between the stacks.
Ok 32 ft lbs it is. I will tighten them this weekend.
Ok, this weekend the major work began. Since all the hydraulic fluid was drained I started by changing the filter. 2013-09-22 15.12.57.jpg.
Finally I started the task of plumbing. 2013-09-22 11.08.24.jpg2013-09-22 17.29.34.jpg2013-09-23 09.09.18.jpg
The most difficult part so far, was routing the one inch hose.
All that remains now, is installing a PB conversion plug, and a JIC 14 connector, both which were on back order.
Looking forward to finally completing my project.
Not much got done last weekend. My JIC14 er, not really a JIC14, but a SAE14 ORB to JIC16 arrived. I just screwed it in and attached the hose.
Here is where the connector went on the loader valve. 2013-09-28 07.32.18.jpg
All that remains now is to install the PB conversion plug.
Still waiting on that. :irked:
211297 (A62131)
211297 (A62131)
2016 WEILER P385A ASPHALT PAVER (A63276)
2016 WEILER P385A...
2020 INTERNATIONAL LT625 48" SLEEPER (A62613)
2020 INTERNATIONAL...
Aluminum Set of Tool Boxes (A62613)
Aluminum Set of...
2009 Kubota M108S (A60462)
2009 Kubota M108S...
John Deere 2155 Tractor W/ Loader (A62613)
John Deere 2155...
