Replacement Directional Control Valve
/ Replacement Directional Control Valve #21
If the recommended torque is 32 ft lbs, I think I would tighten them to 32 ft lbs.
If the pressure causes the o-rings to extrude, you will need new o-rings in between the stacks.
Ok 32 ft lbs it is. I will tighten them this weekend.
Ok, this weekend the major work began. Since all the hydraulic fluid was drained I started by changing the filter. 2013-09-22 15.12.57.jpg.
Finally I started the task of plumbing. 2013-09-22 11.08.24.jpg2013-09-22 17.29.34.jpg2013-09-23 09.09.18.jpg
The most difficult part so far, was routing the one inch hose.
All that remains now, is installing a PB conversion plug, and a JIC 14 connector, both which were on back order.
Looking forward to finally completing my project.
Not much got done last weekend. My JIC14 er, not really a JIC14, but a SAE14 ORB to JIC16 arrived. I just screwed it in and attached the hose.
Here is where the connector went on the loader valve. 2013-09-28 07.32.18.jpg
All that remains now is to install the PB conversion plug.
Still waiting on that. :irked:
Takeuchi TB235-2 (A62177)
Takeuchi TB235-2...
2020 WIRTGEN WR200 XLI SOIL STABILIZER (A62129)
2020 WIRTGEN WR200...
2021 Gehl RT215 Track Loader with 74in Smooth Bucket (A63689)
2021 Gehl RT215...
Greenworks Commercial 82V Utility Vehicle 500 CAMO Model: U500SC - DEMO UNIT (A63689)
Greenworks...
2019 ALLMAND LIGHT PLANT (A65643)
2019 ALLMAND LIGHT...
2018 INTERNATIONAL 4300 S/A 4X2 26FT NON CDL BOX TRUCK (A59914)
2018 INTERNATIONAL...
