Replacement Directional Control Valve
/ Replacement Directional Control Valve #21
If the recommended torque is 32 ft lbs, I think I would tighten them to 32 ft lbs.
If the pressure causes the o-rings to extrude, you will need new o-rings in between the stacks.
Ok 32 ft lbs it is. I will tighten them this weekend.
Ok, this weekend the major work began. Since all the hydraulic fluid was drained I started by changing the filter. 2013-09-22 15.12.57.jpg.
Finally I started the task of plumbing. 2013-09-22 11.08.24.jpg2013-09-22 17.29.34.jpg2013-09-23 09.09.18.jpg
The most difficult part so far, was routing the one inch hose.
All that remains now, is installing a PB conversion plug, and a JIC 14 connector, both which were on back order.
Looking forward to finally completing my project.
Not much got done last weekend. My JIC14 er, not really a JIC14, but a SAE14 ORB to JIC16 arrived. I just screwed it in and attached the hose.
Here is where the connector went on the loader valve. 2013-09-28 07.32.18.jpg
All that remains now is to install the PB conversion plug.
Still waiting on that. :irked:
2012 PREMIER 4NNT PORTABLE PUMP (A63276)
2012 PREMIER 4NNT...
2014 F-150 4WD (A63688)
2014 F-150 4WD...
2013 Hyundai Volster Coupe (A59231)
2013 Hyundai...
Cub Cadet XT1 Riding Mower (A66285)
Cub Cadet XT1...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
MARKER LIGHTS (A64276)
