Comparison Replaced my D105 with a Toro Timecutter Zero Turn
   / Replaced my D105 with a Toro Timecutter Zero Turn #1
ForumJunkie
NY
Toro Timecutter
Went to the local mower shop.
Ended up getting a Toro Timecutter Zero Turn
It was between the SS4225 ($2600) and SS5000 ($2800)
Toro V-Twin motor, 22.5hp vs 24.5hp
50" vs 42" deck (and bigger wheels)
For reference, 42" entry level tractor is $1600
$1900 for one with comparable motor (20hp+)
So, I think +$700 for total paradigm shift was a good move
For 2 acres, I would have gotten the 50" ($200 price diff is trivial)
But, wife felt intimidated by the larger 50"
(Harder to load into pickup, etc?)
So, we went with the SS 4225 for $2600
Wife mowed the lawn today and said it was way more maneuverable and faster.
She quickly got used to the controls, turning around, and says she will get even faster on it
I also looked up the basic maintenance like removing the mowing deck.
Next time, I will be changing stuff like belts and pulleys and oil to avoid the $1000 repair debacle of the Deere D105.
Thanks for all the info on this purchase!!
   / Replaced my D105 with a Toro Timecutter Zero Turn #2
Same machine I have. Works good but traction is terrible, I have a few small slopes and I'm constantly sliding on them.
I can remove the deck in less than 5 minutes, same for putting it back on. I've got the belt number for a Gates deck belt should you need it, 1/2 price of the OE..................Mike
   / Replaced my D105 with a Toro Timecutter Zero Turn #3
Just a note on zeroturn traction: Moving the seat to the rearmost position puts your arse weight onto the drive wheels and GREATLY improves traction over a more forward seat position... Even if you have to make some type of foot rest extension to allow you to brace yourself properly whilst bouncing around the yard.
   / Replaced my D105 with a Toro Timecutter Zero Turn #4
i think zero turns in general are lousy with traction
i have a large Ferris diesel that will get stuck easily. i just avoid wet areas in the spring and fall.
No traction issues. Yard is flat.
5 year update.
The mower has been great.
Zero complaints
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
2014 Freightliner 105' Bucket Truck (A56438)
2014 Freightliner...
Cushman Electric Cart (A55851)
Cushman Electric...
2021 Deere 333G (A53317)
2021 Deere 333G...
SET OF PALADIN JRB 60" PALLET FORKS (A52707)
SET OF PALADIN JRB...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A56438)
2-Row Peanut...
