Time for a Zero Turn
/ Time for a Zero Turn #51
You may want to check the Carlisle Versa Turf as tires. I have them on my SCUT and mow steep hills, they have great traction and don't tear up the lawn.
/ Time for a Zero Turn #52
I put these on my Deere Z960 recently. I only mowed with them 3 times so far but LOVE them!
Yes they are a little more aggressive than turfs when you turn so you need to be careful. But since they get better traction they don't spin as much which is where I was tearing my lawn up. Also they are radials so you can run the pressure lower and you get a smooth ride (they list 20 psi max but mine are running around 10 psi without any problems).
/ Time for a Zero Turn #53
On the ZD 331 I installed rear cast iron suitcase weights. Helps with traction
Mowed the grass yesterday with the Ryobi ZT. First time to mow with much grass growth. Have had a lot of rain recently. Did good.
Mowed one area that I normally only mow once/yr. Had to go over spots with tall grass a 2nd and sometimes 3rd time to get it all. Typical.
/ Time for a Zero Turn #55
I can't speak to your brand comparison questions but I can speak to buying a zero turn. Less than a month ago I made the switch. I had a very trusty but very tired Craftsman YT3000. I've had it for years. Where I lived previously it was fine. But now I have much more lawn to mow and the terrain can be rough. I wanted a commercial grade for those two reasons. I wound up going with a Scag. My mowing life has changed dramatically for the better. I initially wanted a different brand and model but to supply chain issues what I wanted wasn't available and no word on when it would be. So I opted for what I wound up buying. My only regret was not doing it sooner. My weekly cutting time went from 3.5+ hours to less than 1.5. I don't have hills but I do have slopes on my property and it handles it no problem at all.
/ Time for a Zero Turn #56
It is hard to not love a Scag!
/ Time for a Zero Turn #57
So how many acres are you mowing with a battery powered ZT?
KJ K2223 23'x22' Metal Shed (A60463)
KJ K2223 23'x22'...
Deere 310L (A53317)
Deere 310L (A53317)
2025 Miva VA15 (A60463)
2025 Miva VA15...
Sakai SV505 Vibratory Roller (A53317)
Sakai SV505...
2025 MACK GRANITE GR64F DUMP TRUCK (A59823)
2025 MACK GRANITE...
2017 Ford Explorer AWD SUV (A59231)
2017 Ford Explorer...
