Buying Advice Tractor vs zero turn
/ Tractor vs zero turn #142
Do the AT101's have any tendency to tear up turf? sometimes when I get lazy I use my tractor/shredder to mow my yard, and I usually get in trouble for bar tire damage in the lawn...
/ Tractor vs zero turn #143
Been wanting to try them on my ZT but I do alot of spinning in tight quarters and I am guessing they would do some damage. But it might be a push compared to the 'burn' marks I am creating with spinning and sliding issues.
/ Tractor vs zero turn #144
Sometimes in really delicate grass the ATs will cause some scuffing but that’s more due to using a mower that weighs a ton. Overall the ATs are lot better than turfs.
/ Tractor vs zero turn #145
Mostly operator dependent. If you truly "zero turn" it, any tire will scalp, more so on heavier rigs. No different with chevrons. If you are prudent with your sticks, the chevrons overall yield less turf damage due to better traction. But again, if you are a careless operator, you will leave scalp marks on your turns.
Also worth noting, the chevron bar is different than both an R1 & R4 bar.....slimmer, and tapers down from center to outer edge.
/ Tractor vs zero turn #146
I try to Zamboni pattern it as much as I can... I have a few areas where zero turning is pretty much a requirement unless I want to waste a bunch of time jockeying.
/ Tractor vs zero turn #147
The bar tires will tear turf. I have learned how to drive them to avoid it, but if it’s even slightly damp ground, it will happen. If you have the flexibility to be able to allow your property to dry out thoroughly, you might be able to learn to drive them. I have a rigid cutting schedule where I can’t wait too long after rain to cut. That creates a challenge. I’m switching to a less aggressive tire over the winter. Not a turf tire, but not a bar tire either. I think an HDAP tread would be ideal, but I’m still doing my research and reading other alternatives.
/ Tractor vs zero turn #148
I figure the manufacturer’s put turf tires on the mowers because about 90% of the time they work fine. It’s good to have options though.
/ Tractor vs zero turn #149
90% is anecdotal evidence?
I think most people don't know there is an option and I'm wondering how many zero turn salesman even discuss it.
/ Tractor vs zero turn #150
The folks at Town Fair Tire thought I was nuts to put AT101's on a zero turn. Turf damage went down significantly when I switched. The turf tires would frequently spin if the grass was wet or going uphill. The AT101's grab much better so there is no spinning. Of course, I have almost given myself whip-lash on turns!
2018 Dodge Ram 3500 (A53317)
2018 Dodge Ram...
2010 International 7400 Service Truck with Crane, VIN # 1HTWGAAR6AJ276531 (A61165)
2010 International...
2012 Ford E-350 Enclosed Service Van (A59230)
2012 Ford E-350...
(INOP) MASSEY FERGUSON 1552 TRACTOR (A59823)
(INOP) MASSEY...
OMEGA 20 TON CRANE (A58214)
OMEGA 20 TON CRANE...
17101 (A55851)
17101 (A55851)
