Replace with new tractor or add a zero turn mower
   / Replace with new tractor or add a zero turn mower #31
I was also looking at the Cub with the steering wheel. Stopped dead in my tracks when I saw the steering linkage configuration....
Talk about needing a dealer close by. :rolleyes:
I started with a Dixon 4228 42" in '95 when I had 1/2 ac to mow. (~$2k) It took ~ 3hrs to mow 1 1/2 ac when I moved here in '01, so in '06 I bought a CC RZT50". (~$3k) That cut mowing time to ~2 1/2 hrs.
In '15 I bought a Husky MZ-61. This one has a B&S 28hp engine, HG 3100 drives, and a pro (welded) deck. It's like a stripped-down pro model with a homeowner motor (love it) and no ROPS. IMO it's worth every penny of the near $5k I sprung for it. I'm mowing 2 ac now and get done in < 2hrs. Only thing I've done except oil changes, blades (Oregon 95-086), and one belt is to add flat-free front tires.
My personal bugaboo is a disdain for Kohler power. (keep fixing on OPs') Well, that & MMMs.
   / Replace with new tractor or add a zero turn mower #32
i cut my mowing time about 60 % when i got a zero turn.
I think it depends on the size of what you are cutting and the layout. I can cut what I have pretty fast with my tractor but it is 4 acres of mostly grass on a level ground. The zero turn is faster. BUT, my tractor has AC and a nice stereo, so I'd go with my tractor even if it took twice as long in the 95 degree heat with 80% humidity like we get on the coast in the deep south. Don't even get dirty. LOVE mowing with the cab setup. When I mow, it's like a scenic drive in the country with some good tunes and cold air! Rain or shine as well. Just turn the wipers on and enjoy the ride.
2018 PINSA 130BBL VACUUM TRAILER (A58214)
2018 PINSA 130BBL...
John Deere 855DXUV Gator (A57148)
John Deere 855DXUV...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2023 MADJAX GENESIS 300 ELECTRIC CART (A57192)
2023 MADJAX...
Dayton 32965 80-Gallon Horizontal Air Compressor, 22 Volts, 5 HP, 2 Stage, 3 Phase (A59076)
Dayton 32965...
Sedan (A59231)
Sedan (A59231)
