OP
shaeff
Veteran Member
- Joined
- Oct 27, 2015
- Messages
- 1,042
- Location
- Hudson Valley, NY
- Tractor
- MF Utility 35 Gasser, JLG LJ500
Finally got to work on the tractor again, only for a bit. Rechecked the stand pipe, it is properly seated. Still no working rear hydraulics.
I'm going to download the hinge/bracket .pdf from VTE and hinge the top cover plate back off, recheck the adjustments on the control and draft levers, if that doesn't work, pull the pump and spin it with a drill to verify it's actually pumping.
Edit: if I pull the hydraulic transfer plate off the stand pipe and put my finger on the pipe, it feels like it's got VACUUM. No fluid is being pumped into the stand pipe at all. Pump issue?
Thoughts?
Thoughts?
