removing the bucket
/ removing the bucket #1
nh_bota
Bronze Member
Southern NH
Kubota B2620
I looked in the manual, but was unable to find instructions on removing the bucket from the loader arms on my B2620. It looks fairly obvious, but I'm wondering if there are any tricks. Thanks.
Terry
/ removing the bucket #2
Terry
Do you have the quick connect bucket? or standard bucket?
/ removing the bucket #4
I removed my bucket when I installed the QA on my loader, and didn't run into anything unusual. It's a matter of taking out the bolts that retain the pins, and tapping the pins out. Some pins do fit some holes better than others because of paint, tolerances, etc. Even though I still have to tap on usually one pin, I sure do like the QA on mine. Making sure the bucket is sitting pretty level when taking it off, or putting it back on is a good plan!
/ removing the bucket #5
When I took off my bucket to install my Q/A, I put it up on an empty 55 gallon drum, but sawhorses might also work good. It was a bear to grind off the old flanges for the loader arms.
/ removing the bucket #6
Oxy/ acetylene torches...5 minutes or less...
/ removing the bucket #7
Nothing to remove, or modify on my B2620 loader, and hopefully there isn't on your B7610 either. There shouldn't be if you are just taking the bucket off, and not installing some kind of QA. There was no modification of anything using the Kubota QA on mine. Just remove, and replace being careful that the pins with the grease fittings went in the right places.
2014 Honda Accord Coupe (A61574)
2014 Honda Accord...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
2023 CRUISER RV SHADOW CRUISER (A67714)
2023 CRUISER RV...
2018 BRADLEY MACHINE MINI VAC TRAILER (A67714)
2018 BRADLEY...
BAMA BUILT 7x16 Hybrid Dump Trailer (A68134)
BAMA BUILT 7x16...
2017 Ford F-150 Ext. Cab Pickup Truck (A61572)
2017 Ford F-150...
