Removing Mower Deck on D170
/ Removing Mower Deck on D170 #1
doxford jim
British Columbia, Canada
1959 MF-65 sold, 2007 Jinma 554 diesel.
Hi Guys,
Yesterday while mowing I managed to drive over a rather large stone and bent blades of the mower:mad:. Stone was not there last year and I can only assume that the freeze and thaw cycle has pushed this up to the ground surface:confused::confused2:.
Anyway, I would like to remove the deck so I can check spindle trueness and housings as well as remove and replace blades:eek:.
Has anyone done this ? If so how is it done ?
Any help and suggestions would be greatly appreciated.
Thanks
Jim
Thank you - this is exactly what I was looking for. I cannot find the owners manual at home, so the PDF version (now downloaded) is going to be of much use to me.
Thanks again
I got the deck off, repairs made and replaced the deck without any real problems. Was surprised at the weight of the mower deck - I guess 54" is a big size.
Thanks for your help. It really wasn't too bad once I read the instructions (which I didn't have before) and watched the video.
2022 Bobcat E42 (A64126)
2022 Bobcat E42...
John Deere 5420 Tractor with Quicke Loader (A64047)
John Deere 5420...
Oxy-acetylene Torch and Regulator Rig (A63689)
Oxy-acetylene...
Cultivator (A62613)
Cultivator (A62613)
2021 Takeuchi TL10V2-2 Track Loader with 76in Tooth Bucket (A63689)
2021 Takeuchi...
100 Gallon Plastic Tank (A65640)
100 Gallon Plastic...
