Remove your hitch.
/ Remove your hitch. #41
I bet that's exciting when it lets loose.
/ Remove your hitch. #42
With time available...... Soaking with your favourite metal juice....
or/and
Lots of Heat (OA torches).....
Lots of Pull (took two 4x4 trucks pulling inline (dry pavement) on one hitch at my buddy's shop one time....) ......
Lots of Pounding (sledges).......
and, like Chris said, the hitch can still just go to scrap as a one piece item.....
This problem (up here) can lead to people saying "Oh well", and just pulling with a smaller-stuck-in-place ball. :rolleyes:
It's a whole lot simpler/safer/cheaper to just pull the drawbar.....
Rgds, D.
/ Remove your hitch. #43
I just change the ball , why buy two drawbars when I only need one , and its there when I need it . I paint it every second year ............. :)
/ Remove your hitch. #44
That is pretty amazing to see, thanks for posting the pictures. I remove mine when not in use just because I know I will bang a shin or knee sooner or later.
/ Remove your hitch. #45
Whatever works, safely, is all that matters. (Just a general statement.... I'm not implying that you are doing anything unsafe by just changing balls Wawa. That said, would I want the average consumer today changing balls on a drawbar - No.).
Pulling different trailers, I need a different rise on the drawbar - for that reason alone I won't tolerate a fused-in-place drawbar.
Rgds, D.
/ Remove your hitch. #46
I tow a variety of different trailers that require different type inserts so I always pull the insert and keep a light coat of marine grease on everything so no rust forms.
/ Remove your hitch. #47
I believe they are illegal to leave in full time in Saskatchewan for that reason ,the guy behind won't be as lucky but if he just tapped your bumper neither would be hurt.
Not illegal to leave in, in MN; that being said if the hitch or ball obscures your license plate in any way that is illegal. I know an officer that has and will write that citation. Some may just use it for PC to make the stop.
/ Remove your hitch. #48
I tried to pull mine out the other day, been in there since last fall. The hitch itself is loose, can move it up and down. The key cylinder on the pin on the other hand has rusted so bad I can't even get the key in it to unlock. Guess I'm gonna have to hacksaw through the pin.
/ Remove your hitch. #49
Hacksaw may not work. Some of those locking pins are made from hardened steel. Use a grinder to cut one end off.
/ Remove your hitch. #50
If you haven't already, try blowing out some of the crud from the cylinder with compressed air, soak with your favourite metal juice, and repeat - for as long as you have patience..... works sometimes..... at least well enough to release the lock once.
Yet another good example of the "fun" we get to have in salt country...... :rolleyes:
For light duty security (kids w. no tools) I use a pin with a tiny hasp, takes a small padlock, which seems to stand up OK for occasional use. I think it was a Reese part (?).
Good luck, grind safe if it comes to that....
Rgds, D.
/ Remove your hitch. #51
My truck is long enough that the weight-distributing drawbar head I use will hang over the borderline of a downtown parking spot. Esp. in one jurisdiction that is notorious for issuing parking tickets (for anything/nothing), I make sure to take that drawbar off, the odd time I'm downtown with the truck.
Rgds, D.
/ Remove your hitch. #52
guess towing a trailer would obscure your vehicle license plate too eh?
/ Remove your hitch. #53
I believe it is illegal here . Tickets for it are common , Saying that ...when i sold my 1999 F150 i had to pull it out with the backhoe :)
/ Remove your hitch. #54
/ Remove your hitch. #55
Rgds, D.
I did try picking some crud out of the lock, it's pretty solid. I may have caused it. I tried packing the mechanism with never seize before putting the pin in and cap back on. That stuff hardened up so bad I might as well have packed it with JB Weld..
I'm thinking if I smack the lock side with a sledge enough I may just shatter the locking cylinder and pull the pin from the other side. Won't hurt to try anyway.
/ Remove your hitch. #56
A penetrating oil may do a good job of softening up the NeverSz - easy enough to try.
Rgds, D.
/ Remove your hitch. #57
Well, got my pin out. Kinda disappointing though, only took about 30sec. All I did was smack the lock towards the front of the truck with a ball-peen hammer. Spun the pin 180* and hit it again. Took a total of about 4 hits to snap the lock side of the pin right off. Doesn't really reassure me on the security of these things. Needless to say, if someone wants your hitch, they're gonna have it. Only thing these locks do is keep honest people honest.
/ Remove your hitch. #58
that's all any locks or chains or doors and gates do.. keep honest people honest.. and keeps the opportunists out.
the determined guy with a roll off truck and a bag of tools will take what he wants..
/ Remove your hitch. #59
I've started using a lock on the hitch pin also, but mainly for stopping some joker at a rest area pulling my hitch pin while I'm in the restroom. After further thought it may be better to just carry spare hitch pins and make sure I always check the pin before pulling off.
/ Remove your hitch. #60
I'm thinking I'm gonna go to a hardened bolt w/a nyloc nut or double nut. If someone takes the time to remove it, they can have it.
2020 VERMEER LP873SD1 VAC-TRON VACUUM TRAILER (A63276)
2020 VERMEER...
2025 MB27 27in Mixing Bucket Mini Skid Steer Attachment (A61572)
2025 MB27 27in...
Volvo EC55B Exvacator (A62679)
Volvo EC55B...
KUBOTA DM5032 HAY BINE (A64280)
KUBOTA DM5032 HAY...
2016 Ford Escape SUV (A61569)
2016 Ford Escape...
UNUSED SDLANCH SDLGC80 ELECTRIC GOLF CART (A64280)
UNUSED SDLANCH...
