Remove steering wheel 870 JD
/ Remove steering wheel 870 JD #1
klm
Northwest MO
Allis D17 CIH D40, JD5310, Massimo MS50010
I finally have had enough of the fuel and tempertaure gages working intermittenly and decided to pull the instrument panel only I can't get the steering wheel off. I removed the big nut but don't see any way to attach a puller. Has anybody done this?
/ Remove steering wheel 870 JD #2
I have pulled my JD 4200 steering wheel using a tie rod fork and a hammer, after remiving the nut and the spacer rings. You a correct a puller does not have any place to gain a purchase. The wheel has a metal lower section and the flange is metal so the tie rod fork and a big hammer work fine.
Bill
/ Remove steering wheel 870 JD #3
I think you can do it the way we used to pull car steering wheels when I was a teenager (prehistoric times) if you have a helper. Back that big nut off so that the top of the nut is just barely above the top of the spindle so you can't damage the threads. Then with one person pulling up as hard as possible on the steering wheel (hands 180 degrees from each other), the other person gives that big nut a sharp rap with a hammer. It should pop right loose.
/ Remove steering wheel 870 JD #4
<font color="red"> the other person gives that big nut a sharp rap with a hammer. It should pop right loose. </font>
Bird, I just had the funniest Laurel and Hardy moment pass through my head while reading that /forums/images/graemlins/grin.gif
32ft Flatbed Equipment Trailer (A64553)
32ft Flatbed...
JOST FIFTH WHEEL PLATE (A64276)
JOST FIFTH WHEEL...
OK TRUCK & TRAILER SALES PRESSURE WASHER TRAILER (INOPERABLE) (A67714)
OK TRUCK & TRAILER...
2018 Chevrolet Equinox SUV (A66738)
2018 Chevrolet...
2021 PETERBILT 367 (A67714)
2021 PETERBILT 367...
2018 Ford Explorer AWD SUV (A64557)
2018 Ford Explorer...
