Remove Gear Shift Knob
/ Remove Gear Shift Knob #1
mlong75107
Norco, CA
1980 Kubota B7100
I have an older B7100D and need to replace the gear shift boot. I have acquired the boot, but cannot get the gear shift knob off. There is a hole in the middle, if that helps. Any ideas?
/ Remove Gear Shift Knob #2
G'day Mate and welcome to TBN from Downunder.
Gear Shift Knob removal has come up recently in other threads. The consensus seems to be that the knobs are on there permanently and need to be cut off.
Have a look at the bottom of this page in "Similar Threads"... your answer may lay there.
/ Remove Gear Shift Knob #3
Mine are plastic and I believe simply pressed on. Heat would soften the plastic and you should be able to then pry the knob off.
I re-installed my knob by stuffing with hot glue and pushing into place.
/ Remove Gear Shift Knob #4
Heat gun.
Fix something like a pair of vise-grips below the knob, and pry off after careful heating. Heat again, reapply, tap in place
Worked pretty well on my 7610.
2012 MACK Tender Truck w/ADAMS Rear Discharge Bed Auger (A63688)
2012 MACK Tender...
2002 FREIGHTLINER COLUMBIA DAY CAB (A62613)
2002 FREIGHTLINER...
2022 New Holland C327 Compact Track Loader (A63689)
2022 New Holland...
Rotary Auger Motor Attachment (A61572)
Rotary Auger Motor...
2013 Ford Taurus Sedan (A61574)
2013 Ford Taurus...
2006 Lexus ES 330 Sedan (A61574)
2006 Lexus ES 330...
