Rebuilding Ford 4000 engine
/ Rebuilding Ford 4000 engine #1
Jbrandon
Southeast Alabama
Massey ferguson 35 deluxe, Ford 4000
I am in the process of rebuilding the engine in my 1970 ford 4000 3cyl diesel. It had a broken crankshaft. I put everything new in but the rods and the piston height above block was .028 to .038. I figured the rods might be stretched because of the broke crankshaft so i installed new rods and now piston height is .022 to .028 above block. Is the height okay for a .056 head gasket?
/ Rebuilding Ford 4000 engine #2
I would have to look it up, but I believe that is right. The thicker gasket would be correct. The rods would not stretch though.
Thanks for the reply Tractor Tech. A mechanic mentioned that the rods could have stretched and i didn't know what else to try
/ Rebuilding Ford 4000 engine #4
I would probably stay away from that mechanic...
/ Rebuilding Ford 4000 engine #6
Haha, yeah, stay away from this "mechanic". But if you do see him again, ask him how the rods stretch. I think we all want to hear this.
I know he has rebuilt a lot of gas engines. He mentioned it after i told him the crankshaft was broken and it did lower each piston about .008 but i don't know if that is enough. Thanks for all the comments
UNUSED I/A F10 TILT 10' HYD TILT BOX SCRAPER (A57192)
UNUSED I/A F10...
2014 Cadillac ATS Sedan (A59231)
2014 Cadillac ATS...
16001 (A55853)
16001 (A55853)
2015 FORD F-150 LARIAT CREW CAB TRUCK (A59823)
2015 FORD F-150...
2007 Mercedes Benz -S550 AWD Sedan (A59231)
2007 Mercedes Benz...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
