Rebuilding Ford 4000 engine
/ Rebuilding Ford 4000 engine #1
Jbrandon
Southeast Alabama
Massey ferguson 35 deluxe, Ford 4000
I am in the process of rebuilding the engine in my 1970 ford 4000 3cyl diesel. It had a broken crankshaft. I put everything new in but the rods and the piston height above block was .028 to .038. I figured the rods might be stretched because of the broke crankshaft so i installed new rods and now piston height is .022 to .028 above block. Is the height okay for a .056 head gasket?
/ Rebuilding Ford 4000 engine #2
I would have to look it up, but I believe that is right. The thicker gasket would be correct. The rods would not stretch though.
Thanks for the reply Tractor Tech. A mechanic mentioned that the rods could have stretched and i didn't know what else to try
/ Rebuilding Ford 4000 engine #4
I would probably stay away from that mechanic...
/ Rebuilding Ford 4000 engine #6
Haha, yeah, stay away from this "mechanic". But if you do see him again, ask him how the rods stretch. I think we all want to hear this.
I know he has rebuilt a lot of gas engines. He mentioned it after i told him the crankshaft was broken and it did lower each piston about .008 but i don't know if that is enough. Thanks for all the comments
(INOP) CASE IH MAGNUM MX285 TRACTOR (A62130)
(INOP) CASE IH...
2007 Ford F750 Dump (A62613)
2007 Ford F750...
UNUSED SDLANCH SDLFP30 EELCTRIC PALLET JACK (A62131)
UNUSED SDLANCH...
UNUSED JCT 72" HYD TILLER (A62131)
UNUSED JCT 72" HYD...
Hustler Super Z 72in. Zero Turn Commercial Mower (A61567)
Hustler Super Z...
2022 Husqvarna Z560L Zero Turn (A63116)
2022 Husqvarna...
