Buying Advice Rebuild old JD110 or replace?
/ Rebuild old JD110 or replace?
Thanks everyone for your input. I came very close to buying a Zero turn mower but the more I read about the handling on hills the more I decided it wasn't for me. I have a lot of 15-20 degree hills and a lot of rough area that I cut. I think front wheel steering and 4 good wheels on the ground would be a better fit for me. I have looked at so many tractors that I can't remember which is which. I found one that had a Tuff Torq k57 and thought it would have been more robust than the K46 all of the others had. Then I came across an article on CTV transmissions for garden tractors; that sold me. I like the idea that there are no pumps, motors or hydraulic oil to wear out. Time will tell If I made the right decision or not. I ordered a Husqvarna YTA24V48 24-HP V-Twin Automatic 48-in Riding Lawn Mower. The 'YTA' in the model number denotes a CTV transmission, 'YTH' is the k46 hydro version. Here is a link to the article and videos on the CTV transmission.CVT Automatic Transmissions – Simple to use, ideal for all terrain.
/ Rebuild old JD110 or replace? #22
How does a person determine what model transaxle is on their riding mower?
Is there a list of light duty through heavy duty transaxles?
I have a Craftsman LT2000 that was like new before I took it out to the ranch... it's been two years and gets used hard... the first job it did with 2 acres for waist high grass... had to open the chute and cut about 16" swaths and felt sorry for the poor machine all day...
/ Rebuild old JD110 or replace? #24
What a wealth of information... thank you!
/ Rebuild old JD110 or replace? #25
You want a zero turn.
Now that I've bought a new lawn tractor, I decided to put my transmission back together. I cleaned the filter and magnets, sealed the case, added 10w40 synthetic oil, and reinstalled it on my tractor. It runs like new!
/ Rebuild old JD110 or replace? #27
Good Deal... and it takes up a lot less room put together!
/ Rebuild old JD110 or replace? #28
Zero Turns do ok on hills if the slippy turf tires are replaced with ATV tires.
2019 HAULOTTE 5533A PORTABLE ELECTRIC BOOM LIFT (A65056)
2019 HAULOTTE...
2023 CATERPILLAR 259D3 SKID STEER (A65056)
2023 CATERPILLAR...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
PORTA POTTY (A67714)
2014 ISUZU NPR S/A 4X2 17FT BOX TRUCK (A69167)
2014 ISUZU NPR S/A...
PALLET OF HEAVYEQUIPMENT PUMP PARTS (A68842)
PALLET OF...
