Buying Advice Rebuild old JD110 or replace?
/ Rebuild old JD110 or replace?
Thanks everyone for your input. I came very close to buying a Zero turn mower but the more I read about the handling on hills the more I decided it wasn't for me. I have a lot of 15-20 degree hills and a lot of rough area that I cut. I think front wheel steering and 4 good wheels on the ground would be a better fit for me. I have looked at so many tractors that I can't remember which is which. I found one that had a Tuff Torq k57 and thought it would have been more robust than the K46 all of the others had. Then I came across an article on CTV transmissions for garden tractors; that sold me. I like the idea that there are no pumps, motors or hydraulic oil to wear out. Time will tell If I made the right decision or not. I ordered a Husqvarna YTA24V48 24-HP V-Twin Automatic 48-in Riding Lawn Mower. The 'YTA' in the model number denotes a CTV transmission, 'YTH' is the k46 hydro version. Here is a link to the article and videos on the CTV transmission.CVT Automatic Transmissions – Simple to use, ideal for all terrain.
/ Rebuild old JD110 or replace? #22
How does a person determine what model transaxle is on their riding mower?
Is there a list of light duty through heavy duty transaxles?
I have a Craftsman LT2000 that was like new before I took it out to the ranch... it's been two years and gets used hard... the first job it did with 2 acres for waist high grass... had to open the chute and cut about 16" swaths and felt sorry for the poor machine all day...
/ Rebuild old JD110 or replace? #24
What a wealth of information... thank you!
/ Rebuild old JD110 or replace? #25
You want a zero turn.
Now that I've bought a new lawn tractor, I decided to put my transmission back together. I cleaned the filter and magnets, sealed the case, added 10w40 synthetic oil, and reinstalled it on my tractor. It runs like new!
/ Rebuild old JD110 or replace? #27
Good Deal... and it takes up a lot less room put together!
/ Rebuild old JD110 or replace? #28
Zero Turns do ok on hills if the slippy turf tires are replaced with ATV tires.
1819 (A64557)
1819 (A64557)
2018 Ford E-450 Shuttle Bus (A61573)
2018 Ford E-450...
2022 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A66736)
2022 Chevrolet...
2014 PETERBILT 579 MID-ROOF SLEEPER (A67714)
2014 PETERBILT 579...
2006 SUPERLINE DO20T192ALP T/A 20FT TRAILER (A66091)
2006 SUPERLINE...
1998 Freightliner MT45 Chassis Truck (A66736)
1998 Freightliner...
