Rear wheel weights
/ Rear wheel weights #21
Don't block the access from maint. Esp. grease fittings,Wheels bearing, adj. the brakes etc.. Or easy to remove or move them if needed. Weight on 3Pt. hitch would be about the same principal. JMO!
/ Rear wheel weights #22
But the fill liquid is far more than $100.
Yeah if you buy beet juice which is overkill. You can use antifreeze mixed with water or pay more and buy Ethanol. Either way the fluid can be reused when you get new tires..
/ Rear wheel weights #23
I guess it depends on the tire size/volume. Mine have corn juice (Bioballast) not beet juice.
/ Rear wheel weights #24
I ordered 5 gals of machinist lube from Amazon and got it mixed fluid enough to put a gal in each tire then filled with water. Keeps rims from rusting.
/ Rear wheel weights #25
You must not worry about freezing.
/ Rear wheel weights #26
Depends on what you want to fill with.
In Florida they use straight water.
I've used used antifreeze that was free.
/ Rear wheel weights #27
I've seen that used. The downside is that if you punch a tire, you are going to be spewing antifreeze onto the ground.
With my luck that would happen within the reservoir of my dug well.
Yes and no. 3pth weight only works when it's in the air. Before I added wheel weights I was out disking my garden on a slight sidehill and had a hard time keeping the uphill rear on the ground. After adding 400 lbs of wheel weights I don't even think about it.
/ Rear wheel weights #28
My Yanmar isn't positive traction, so I really have to be careful on it. Happened a few times. Drive side looses traction and your as! is stuck! sideways on a hill. The FM mower will lock it up and prevent any rollover. Pucker factor is way up there when it happens!!! Never happened on my Ford yet! Found out Anti freeze was in the rear tires when I bought it. Also the 3Pt. lock on the Yanmar so it stays up if needed running or not. Nice option!
/ Rear wheel weights #30
I have a backhoe on my l series.
The rear wheels rarely come up
My B series has weighs and it makes a huge difference
/ Rear wheel weights #31
Should have bit the bullet 10 years ago but I didn’t until now. Didn’t want fluid in the tires so I bought 6 107# weights for my kubota L 5740. View attachment 3172095
Did you have any ballast previously? Filled tires, for example?
I had filled tires on my 5740, but it was still light in the rear with a full bucket load of material. I added wheel weight, so now have both and it makes a huge difference.
Every loader I have ever seen REQUIRES ballast, and exactly how much or what combinations are spelled out in the manual.
No fluid, just always had something on three point when using front end loader, still plan on doing that with the weights.
2015 Honda Accord Sedan (A66738)
2015 Honda Accord...
2014 (INOPERABLE) FREIGHTLINER CASCADIA (A67714)
2014 (INOPERABLE)...
FOUR PALLETS OF MISC ITEMS (A67714)
FOUR PALLETS OF...
2019 Chevrolet Tahoe SUV (A66738)
2019 Chevrolet...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A66736)
2016 Ford F-150...
2018 MACK PINNACLE (A67714)
2018 MACK PINNACLE...
