Rear scraper blade
/ Rear scraper blade #1
shui5612
Montreal
2013 Yanmar SC2450, 2008 Kubota ZD326, 1986 Deutz 7085
Morning gentlemen,
I stumbled across a rear scraper blade that has hydraulics to make the blade lay down, I.e. it doesn't appear to even be able to turn left or right simply "flatten" out (moldboard more parallel to the ground) or raise (mold board becomes perpendicular to the ground).
I believe this changes how aggressively the blade bites into what you are scraping (biting in vs leveling out) is my thinking on the right track? Why aren't there more blades that offer this option if it is useful?
Ill try to get pictures tomorrow of it.
Really confused about it's useage since it doesn't angle or tilt as far as I can tell.
/ Rear scraper blade #2
It may be a ditching tool - ................
gg
/ Rear scraper blade #3
Somebody had some specialized use in mind. So specialized that you have to make your own to get one??
2011 TROXELL 140BBL TRI AXLE VACUUM TRAILER (A65643)
2011 TROXELL...
2023 ANDERSON IFX720 CONTINUOUS BALE WRAPPER (A64277)
2023 ANDERSON...
2024 JOHN DEERE TURF GATOR (A63276)
2024 JOHN DEERE...
(2) New 27X8.5-15 turf tires in John Deere 6-lug compact tractor rims, Coal Valley, IL (A65640)
(2) New 27X8.5-15...
2012 DRAGON  130BBL VACUUM TRAILER (A65643)
2012 DRAGON...
2009 VOLVO VHD BOBTAIL VACUUM TRUCK (A65643)
2009 VOLVO VHD...
