rear hydraulics going wonky
/ rear hydraulics going wonky #1
2023KIOTI NS 4710
so i am pretty sure I left the rear implement in the up position last time I parked the tractor for a week or so. when I got in today I found the lever for 3pt lift all the way forward (which I never do). so I thought that was strange. but I started it up. and immediately found the 3pt lift to shudder when moving both up and down. not every time and definitely depends on how youre working the lever but I've never seen it do what it's doing now. it'll jerk while moving into position.. before it would only jerk it I rapidly moved brush hog upwards.
this is a KIOTI ns4710hst
it has 11 hours on it.
anyone have any ideas? I'm hoping it'll be normal tomorrow.... lol
/ rear hydraulics going wonky #2
Check your fluid level.
Make sure you do not have the draft control on.
/ rear hydraulics going wonky #3
Might need a filter change - start with the simple easy stuff first
/ rear hydraulics going wonky #4
Why would you leave the tractor with the 3pt up? You prob just have air in the system so cycling it should help.
2011 TORO SP5040 MOWER (A66091)
2011 TORO SP5040...
2000 KENWORTH T800 CRANE TRUCK (A67714)
2000 KENWORTH T800...
12IN CENTRIFUGAL PUMP (A67714)
12IN CENTRIFUGAL...
FUEL TANK (A68842)
FUEL TANK (A68842)
2023 CRUISER RV SHADOW CRUISER (A67714)
2023 CRUISER RV...
213141 (A64276)
213141 (A64276)
