K5lwq
Elite Member
- Joined
- Aug 6, 2017
- Messages
- 4,921
- Location
- Mineola, TX
- Tractor
- Kioti LK2554, Branson 4815C, Satoh Beaver, Speedex
In my efforts to resolve my issue, your statement above is my conclusion.
If it's valve failure, I have 5 bad valves on 2 tractors. I struggle to believe that.
I have to agree with you. Highly unlikely all you valves are bad. If they are, you should buy a lottery ticket! Also, being one of the smartest guys on this forum, if have not found a solution, likely one doesn't exist. The solution is going to be the best work around.
The question we don't know the answer is if the OP situation is worse than you and others are experiencing? Seems like he is getting more air than most.
With respect to your other implements, the more I think about it very few applications are like the top links.
I am not sure if I have adjusted top link with the implement off the ground. Probably more of habit than anything because all the years of manual top link adjustments. I always did those on the ground because it is easier. I guess I could try it to see if I get a similar result.
