Dirt Moving Rear hydraulic remote .
/ Rear hydraulic remote . #141
That’s not been my experience at all on the larger tractors.
Ok sounds good but will probably have to print it out , laminate it and stick it somewhere convenient. lol . Will let you know what happens next. Thanks for your help.
Just a quick update. I have tried all that’s been suggested but the problem still exists. The top link moves in and out but maybe not as much as when I started but nevertheless it moves quite a lot. I have persevered on the occasions that I have used the rake and this is the lightest implement so I can only assume that it will perform worse with the the heavier box blade etc. With this in mind and reading all the posts I think I will revert back to the old screw top link. It sounds like it is likely to be an expensive fix not to mention the time lost, and as I don’t use the tractor on a very regular basis ( which is why it’s taken so long for this update ) I have to ask the question— is it worth it ? Thanks to all who have tried to help but I have come to the conclusion that it seems to be a regular hydraulic problem, I only wish I had known this beforehand.
/ Rear hydraulic remote . #143
I hate to hear you are giving up on the cylinder but I certainly understand. Something very unique is going on with your system and it very well may not be worth the trouble.
I love the convenience of my top and tilt setup but have never experienced the issues you are seeing. I personally would love to understand what is going on with your system but as CB has already told me I could be making a mountain out of a mole hill.
Anyway, thank you for the update.
/ Rear hydraulic remote . #144
I originally put on top and tilt cylinders with no check valves
The top link cylinder would move in/out when under load and was basically useless for grading with the box blade (wouldn't stay where I put it.)
Also the tilt cylinder would constantly drift off and needed constantly pulled back up.
I got rid of the top and tilt cylinder after about a year and replaced them both with cylinders with the double piloted check valves.
Never a problem since. They stay where I put them and work great for the past 17-18 years they have been on there.
Check valves solved my problem.
/ Rear hydraulic remote . #145
Good information. No difference in speed of travel or ability to fine tune?
/ Rear hydraulic remote . #146
No. Just as fast and smooth as the cylinders I had without check valves.
Only difference I noticed is they stay where I put them.
/ Rear hydraulic remote . #147
Excellent information.
WARREN POWER SYSTEM LIGHT PLANT (INOPERABLE) (A68842)
WARREN POWER...
2009 ALLMAND MAXI-HEAT MH1000 HEATER TRAILER (A67714)
2009 ALLMAND...
2011 Chevrolet Impala Sedan (A66738)
2011 Chevrolet...
500 GAL WATER TANK (A68842)
500 GAL WATER TANK...
ENCLOSED OPERATOR CAB (A67714)
ENCLOSED OPERATOR...
2015 DODGE CHARGER CAR (A66091)
2015 DODGE CHARGER...
