Dirt Moving Rear hydraulic remote .
/ Rear hydraulic remote . #141
That’s not been my experience at all on the larger tractors.
Ok sounds good but will probably have to print it out , laminate it and stick it somewhere convenient. lol . Will let you know what happens next. Thanks for your help.
Just a quick update. I have tried all that’s been suggested but the problem still exists. The top link moves in and out but maybe not as much as when I started but nevertheless it moves quite a lot. I have persevered on the occasions that I have used the rake and this is the lightest implement so I can only assume that it will perform worse with the the heavier box blade etc. With this in mind and reading all the posts I think I will revert back to the old screw top link. It sounds like it is likely to be an expensive fix not to mention the time lost, and as I don’t use the tractor on a very regular basis ( which is why it’s taken so long for this update ) I have to ask the question— is it worth it ? Thanks to all who have tried to help but I have come to the conclusion that it seems to be a regular hydraulic problem, I only wish I had known this beforehand.
/ Rear hydraulic remote . #143
I hate to hear you are giving up on the cylinder but I certainly understand. Something very unique is going on with your system and it very well may not be worth the trouble.
I love the convenience of my top and tilt setup but have never experienced the issues you are seeing. I personally would love to understand what is going on with your system but as CB has already told me I could be making a mountain out of a mole hill.
Anyway, thank you for the update.
/ Rear hydraulic remote . #144
I originally put on top and tilt cylinders with no check valves
The top link cylinder would move in/out when under load and was basically useless for grading with the box blade (wouldn't stay where I put it.)
Also the tilt cylinder would constantly drift off and needed constantly pulled back up.
I got rid of the top and tilt cylinder after about a year and replaced them both with cylinders with the double piloted check valves.
Never a problem since. They stay where I put them and work great for the past 17-18 years they have been on there.
Check valves solved my problem.
/ Rear hydraulic remote . #145
Good information. No difference in speed of travel or ability to fine tune?
/ Rear hydraulic remote . #146
No. Just as fast and smooth as the cylinders I had without check valves.
Only difference I noticed is they stay where I put them.
/ Rear hydraulic remote . #147
Excellent information.
2007 Mack CV713 Granite T/A Pole Truck (A62679)
2007 Mack CV713...
UNUSED MOWER KING-AGT SAII100 (A64281)
UNUSED MOWER...
17in. Tooth Excavator Bucket (A64194)
17in. Tooth...
1901 HOMEMADE 16FT T/A TILT TRAILER (A59906)
1901 HOMEMADE 16FT...
2016 JCB 3CX 4x4 Loader Backhoe (A64194)
2016 JCB 3CX 4x4...
2006 Hitch and Trailers Inc. 12ft S/A Utility Trailer (A61574)
2006 Hitch and...
