Rear finishing mower
/ Rear finishing mower #1
muddwhumper
Knoxville, Tennessee
Massey-Ferguson
I have read some of the other posts about rear finishing mowers. I was wondering if they are worth the money? And can my MF 135 pull a 7' mower. I have about 2-3 acres to mow and it is wearing out my little 38" riding mower. I have been wondering about these mowers for a while. What is the one that is the best and worst? I appreciate all of y'alls help in this forum--it really helps us newbees.
/ Rear finishing mower #2
Not sure about your MF 135 pulling a 7’ RMM. But I was able to pull a 5’ woods behind a Kubota B-6000 (~10 hp PTO) with out any problems. It would cut through some pretty heavy grass and even some small saplings.
From what I can tell the MF 135 is in the 45 hp range, if so, you should have no problems.
Good luck,
Gary
/ Rear finishing mower #3
The answer depends on the PTO Horse Power and lift capacity of your 3 Point Hitch.
Per the info I've found, you're pretty close to 40 PTO Horsepower. You should have no problem running a 7' mower.
/ Rear finishing mower #4
Mud, My 135 pulls a 6' with ease no problem at all , I'm sure as long as you don't let the grass get way overgrown it would also handle a 7' finish mower ...lot's of power in those diesel 135's ,38hp they will handle 6' rotary ,but mine came with a 5' so thats what I use..
Oh you want to cut your time from hours mowing to minutes ?
I would reccommend no bigger than 6' just because of pricing and for 3 acres you'll be done in about 59minutes...
Say, did you ever decide on your P/S and loader ideas?
I have decided to wait on adding pwr steering. I have priced some units and it seems like it is going to be a big headache for now. I think I will concentrate on getting implements for the MF. I have found a little 3 pt dirt scoop for 175 here locally and I think for the small amount of dirt I would need to move it would be worth the money. I will also need an auger and RFM for mowing. Thanks for all the ideas and support on this forum.
2011 FORD F-150 (A65643)
2011 FORD F-150...
2007 Allmand Max-Lite ML20 20KW Towable Light Tower (A64194)
2007 Allmand...
2012 FREIGHTLINER M2 6X4 T/A DAY CAB TRUCK (A66091)
2012 FREIGHTLINER...
72in. Land Plane (A65640)
72in. Land Plane...
2012 HINO 268 4X2 S/A BOX TRUCK (A59914)
2012 HINO 268 4X2...
2018 Freightliner M2 106 20Ft. Reefer Box Truck (A64194)
2018 Freightliner...
