Chains rear chains for 1220
/ rear chains for 1220 #1
ochambers
western NY
'93 Ford 1220 4x4
I bought a used 1220 4X4 with turf tires. To avoid the expense of going to Ags, I bought a set of chains. The rears did not fit. Store won't take them back. They don't fit because there is not enough room between the turf tire and the fender. Can wheels be reversed for more room? Can spacers be installed? Any other ideas would be appreciated.
/ rear chains for 1220 #2
My rear turfs have a offset on the rims so I can turn them either way,yours might have the same type.Tom
Tom, forgive my ignorance, does this offset, by turning rims around, give me more room between the tires and fender? Thanks for your response. DR
/ rear chains for 1220 #4
It will give more distance between the sidewall of the tire and the fender,nothing changes to the outside diameter of the tire unless you let some air out.hope this helps,Tom
/ rear chains for 1220 #5
Yes, by reversing your rims the chains will clear your fenders. I have used chains on mine by doing this with no problems. Remember to tie up any extra links to keep from banging the fenders.
Bryan, Thanks loads for your info on the chains for the 1220, that helps out alot. Is this web site cool or what?!
"DR"-Buffalo
/ rear chains for 1220 #7
Yes, this is a great site to see what is being said about other people's experiences. A co-worker told me about it last week, because he is buying a compact tractor soon. N.H. or K.
Brian, I finally got around to reversing the rims on my 1220 and it worked out just like you said and what a difference in the traction! Thanks again. "DR"
Hydraulic Breaker Excavator Attachment (A64553)
Hydraulic Breaker...
2021 PETERBILT 367 (A65643)
2021 PETERBILT 367...
CATERPILLAR CS44B SMOOTH DRUM ROLLER (A64279)
CATERPILLAR CS44B...
2026 SDLANCH SDLMG1220F Galvanized Metal Livestock Shed (A64194)
2026 SDLANCH...
2018 BOBCAT E50 EXCAVATOR (A65053)
2018 BOBCAT E50...
2021 KUBOTA KX080-4 SUPER SERIES 2 EXCAVATOR (A65053)
2021 KUBOTA...
