Ready made 3 point brackets
/ Ready made 3 point brackets #1
bdog
Elite Member
Texas
John Deere 6130M
Years ago I thought I saw somewhere that sold 3 point brackets that you could weld onto whatever. If my memory serves me right it was just a 4" x 1/2" strap that was pre bent and had the holes in the right spots for the pins. I know these would not be hard to make but I have got some bigger toolbar implements I am going to cut down and make smaller implements and I was thinking this would be an easy route and would ensure my dimensions were correct so quick hitches would work. Problem is I can't seem to find them anywhere.
/ Ready made 3 point brackets #3
I've seen tractor side parts like these: Content Page and Content Page
But never pre-made universal implement side parts (other than the pins themselves).
They looked similar to what Fred posted minus the ball mount of course. I don't remember the price but at the time I thought they were cheaper than they could be built for. For $100 I would just make my own.
/ Ready made 3 point brackets #6
That is what I did on all my either home made implements or the revamped implements , Was just build my own . Steel dealer I go to here , has both new steel and old stock / recycled steel , thus if I can't find it in the old steel racks , I can get it new . Last time I bought steel , old was like $ .60 a pound , so I could over build with some pretty heavy duty steel and still come out $$$ ahead as opposed to buying a ready made pre-bent hitch .
Fred H.
/ Ready made 3 point brackets #7
If you have a few to make, it may be worth buying a shop press and bender. The HF press and SWAG bender will do that width 1/2" flat bar no problem. Probably run about $25 a piece in materials.
/ Ready made 3 point brackets #9
BigTyme : Says it fits all Cat 1 tractors but has it seems with all the quick hitches and different makers of implements , there seems to be no standard on pin width thus in answer to your question ???
Fred H.
/ Ready made 3 point brackets #10
Thanks Fred, I guess it wouldn't be to much work to make it fit for the price.
/ Ready made 3 point brackets #11
Reading what everybody has said about their various quick hitch's , It seems like they all have to adapt the hitch or the implement through various means via longer pins or other methods . I have a similar set up to Pats Quick hitch and Once I set that width , I had to adjust every implement to it . From A King Kutter 6' disk , a 5' New Holland Brush Hog , to home made implements . Some were simple just by adding a longer pin to welding on new pin mounting plates or even in 1 case , I reversed the pins to adapt a Cat 2 or maybe a Cat 3 ( ??? ) rear carry all to fit my tractor .
Not much $$$ spent on each , just a little time and thought process , Which for me is a bigger problem than the $$$ side !! :thumbsup:
Fred H.
/ Ready made 3 point brackets #12
/ Ready made 3 point brackets #13
2012 Ford F-250 Crew Cab Pickup Truck (A64556)
2012 Ford F-250...
2016 Nissan Frontier Crew Cab Pickup Truck (A66736)
2016 Nissan...
2027 . . (A67714)
2027 . . (A67714)
93b (A65054)
93b (A65054)
2019 CHEVROLET TAHOE (A66091)
2019 CHEVROLET...
2021 PETERBILT 367 (A65643)
2021 PETERBILT 367...
