Ready made 3 point brackets
/ Ready made 3 point brackets #1
bdog
Elite Member
Texas
John Deere 6130M
Years ago I thought I saw somewhere that sold 3 point brackets that you could weld onto whatever. If my memory serves me right it was just a 4" x 1/2" strap that was pre bent and had the holes in the right spots for the pins. I know these would not be hard to make but I have got some bigger toolbar implements I am going to cut down and make smaller implements and I was thinking this would be an easy route and would ensure my dimensions were correct so quick hitches would work. Problem is I can't seem to find them anywhere.
/ Ready made 3 point brackets #3
I've seen tractor side parts like these: Content Page and Content Page
But never pre-made universal implement side parts (other than the pins themselves).
They looked similar to what Fred posted minus the ball mount of course. I don't remember the price but at the time I thought they were cheaper than they could be built for. For $100 I would just make my own.
/ Ready made 3 point brackets #6
That is what I did on all my either home made implements or the revamped implements , Was just build my own . Steel dealer I go to here , has both new steel and old stock / recycled steel , thus if I can't find it in the old steel racks , I can get it new . Last time I bought steel , old was like $ .60 a pound , so I could over build with some pretty heavy duty steel and still come out $$$ ahead as opposed to buying a ready made pre-bent hitch .
Fred H.
/ Ready made 3 point brackets #7
If you have a few to make, it may be worth buying a shop press and bender. The HF press and SWAG bender will do that width 1/2" flat bar no problem. Probably run about $25 a piece in materials.
/ Ready made 3 point brackets #9
BigTyme : Says it fits all Cat 1 tractors but has it seems with all the quick hitches and different makers of implements , there seems to be no standard on pin width thus in answer to your question ???
Fred H.
/ Ready made 3 point brackets #10
Thanks Fred, I guess it wouldn't be to much work to make it fit for the price.
/ Ready made 3 point brackets #11
Reading what everybody has said about their various quick hitch's , It seems like they all have to adapt the hitch or the implement through various means via longer pins or other methods . I have a similar set up to Pats Quick hitch and Once I set that width , I had to adjust every implement to it . From A King Kutter 6' disk , a 5' New Holland Brush Hog , to home made implements . Some were simple just by adding a longer pin to welding on new pin mounting plates or even in 1 case , I reversed the pins to adapt a Cat 2 or maybe a Cat 3 ( ??? ) rear carry all to fit my tractor .
Not much $$$ spent on each , just a little time and thought process , Which for me is a bigger problem than the $$$ side !! :thumbsup:
Fred H.
/ Ready made 3 point brackets #12
/ Ready made 3 point brackets #13
2013 Jeep Wrangler 4X4 SUV (A66738)
2013 Jeep Wrangler...
1999 22ft Express Trailers T/A Enclosed Cargo Trailer (A66738)
1999 22ft Express...
2021 CATERPILLAR 308CR EXCAVATOR (A65056)
2021 CATERPILLAR...
PORTA POTTY (A67714)
ENCLOSED OPERATOR CAB (A67714)
ENCLOSED OPERATOR...
2006 FORD E450 UTILITY TRUCK (A66091)
2006 FORD E450...
