ready for ivan
/ ready for ivan #1
Soundguy
Old Timer
Central florida
RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
Well.. I've got my pto generator setup.. tractor parked outside house, extension and hookup cables ready.. enough fuel for days of running. I also have a spare battery 12v battery charging, in case I need to use it to jump the tractor, or to run a small inverter that I just finished repairing. i also have a 12v automotive neon drop lamp.. uses almost no power. Flashlights, candles, lamps and oil are ready... I went out and braced up and reinforced the animal pens outside, and picked up any remaining debri. Now I just hope ivan passes florida by.
Soundguy
/ ready for ivan #3
Good for you, Chris. Ivan will probably miss you now; it's when you aren't prepared that you get hit, isn't it? /forums/images/graemlins/wink.gif
/ ready for ivan
Thanks guys!
Soundguy
/ ready for ivan #5
This may (most likely is) be a stupid question...
Can your ignition system (distributor) handle the wind driven rain? You are using it on your gas tractor right?
I wish the best for you and the rest of Florida.
/ ready for ivan #6
I looked on the map to see exactly where you lived. I couldn't believe it.... found Central Florida right away... /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif Good luck and lets hope that this is the last one of the season and it passes you by....
/ ready for ivan #7
Good luck with this second storm coming in!
Was by the Home Depot in Sacramento Ca. today. They had a sign up that there were no generators available; all were being shipped to Florida and other parts of the South-East.
They said on the news out here that most people have left thier storm protection in pace, rather than remove and reinstall again.
/ ready for ivan #8
Chris.........I have a brother & sister both in N. Ft. Myers. They got thru the 1st two very lucky ..... only very minor damage.............They kept their sense of humor thru it all...........See attached photo of postcard my brother sent me today..............Good luck to you !! TOM
/ ready for ivan #9
Sure hope this next one misses you all together, and if so, you have to fire up all the cool stuff and let us know if it would have worked had it been needed.
My prayers are with you guys, hope this one leaves you alone!
/ ready for ivan #10
Tom, I got the same photo yesterday from friends in Lady Lake, FL. /forums/images/graemlins/laugh.gif
/ ready for ivan
My homeowners ins. agent also sent me that emial.. pretty funny i thought.
Soundguy
/ ready for ivan
</font><font color="blue" class="small">( Can your ignition system (distributor) handle the wind driven rain? You are using it on your gas tractor right? )</font>
So far it is doing ok. The side mounted distribuitor on the late 8n's seals really good. OI have new 8mm wires and boots on.. and well.. they are tight. Cap has a seal as well. I sprayed it all down with wd-40, and so far have had no water problems.
I had though about sliding a grocery bag over it and wire tieing it off. Lots of the guys that trailer their tractors to shows do this to keep the rain out.
Soundguy
2016 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2016 Chevrolet...
2016 Nissan Titan XD Crew Cab Pickup Truck (A61573)
2016 Nissan Titan...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
Sakai SW354 (A60462)
COMBINE RIM FOR JOHN DEERE (A63291)
COMBINE RIM FOR...
2025 44in Hydraulic Grapple Mini Skid Steer Attachment (A61572)
2025 44in...
