Re-tip your hammers
/ Re-tip your hammers #1
fishfactor
Monroe, NC
(2) 2014 CAT 299DXHP / FECON
After being frustrated over the price of new hammers (teeth) for a while. I finally came across a company that can re do them. Bobcat is really proud of their teeth.
I sent my broken teeth to Jonas at Freight Shield | Door Jamber | Carbide Tools | OpTeam Products and he sent them back in about 4 weeks. They look good to be re works and I'll be bolting a few on to see how they last. I plan to mark them to distinguish them from the OEM teeth.
Jonas was good to work with and saved me a good chunk of change. I'll be replacing broken teeth much quicker now instead of running them as long as I can.
Just wanted to pass this along in case it can save any of you guys a few bucks.
Weight is the same... I'll take pics this week and post.
Look close and you can see where they welded to build back up the areas that were worn due to running the teeth after the carbide was broken. Now I'll be changing them as they break so this shouldn't be an issue.
Yep.. these are off of a bobcat cutter. I really don't want to quote his prices, but they were less than half of what my bobcat dealer sells the new ones for. He said he can also switch them to planer teeth (must send him a full set to avoid weight issues).
He told me he could do virtually any type of tooth as long as he had a good sample to work off of.
/ Re-tip your hammers #7
I wonder if they can fabricate a carbide edged cutter bar? I've flipped my cutter bar 4 times, now need to visit a machine shop for new edges. It gets rounded over in only 100-150 hours. When material starts to jam frequently, it's generally rounded over. A long carbide edge would really help. A new bar is $138 plus shipping from Loftness.
Robbie, that's your grinder on the ground.
I've been running several of the re worked teeth now for two weeks. They show no signs of failure or anything unusual. Haven't caused any balance issues on the head.
/ Re-tip your hammers #9
how are teeth workin out.im tired of paying out the nose for teeth
So far, so good. They have held up to several rocky jobs with no signs of failure. I won't be buying any more new ones if I can help it. I think it's been about 6 weeks or more.
I didn't make note of the hours, but somewhere between 150 and 200.
/ Re-tip your hammers #13
thats awesome .im going to call them tomorow and quiz them.thats a deal
/ Re-tip your hammers #14
I need my bobcat teeth redone. The link is dead. a google search shows nothing
Give Jonas a call (901) five zero three -0250
2013 Ford Flex SUV (A64557)
2013 Ford Flex SUV...
2188 (A65055)
2188 (A65055)
2023 VOLVO L90H WHEEL LOADER (A64279)
2023 VOLVO L90H...
Wooden Glider Chair (A64557)
Wooden Glider...
2016 John Deere 85G Midi Excavator (A64553)
2016 John Deere...
2155 (A65055)
2155 (A65055)
