Oil & Fuel Re glow plug life
/ Re glow plug life #1
fordman6442
Terrace B.C. Canada
67 massey 165,1947 Farmall A, 1949 Massey Harris, 1955 Ford 600 with b/hoe and loader J.D. 350 Crawler with winch and 6 way blade,Kabota riding mower, Husquavarna riding mower,Kawasaki quad and a wife
I have a Kubota B2320 with 264 hours on it. Is it common for this unit to have glow plug failure. When I start it now it fires on one cylinder for 10-20 seconds then picks up and starts on the other 2. I haven,t called my dealer as it is Sat night. Any input??
/ Re glow plug life #2
Glow plug testing is a simple matter. I have had no problems with the BX2200 but I have had with my VW diesels.
First remove the glow plugs. Then you can use a jumper cable and clamp one end on the - batt post and hold the body of the glow plug in the other end,you can touch the top of the plug to the + batt.,post and see if it lights up. A good glow plug will turn red fairly quickly.
Plug life seems to be hit and miss.
Dan
/ Re glow plug life #3
Or - you can use an Ohm meter to test the resistance across the plug. I would have to check the shop manual to see what the resistance is supposed to be. However, if you have an open circuit, then that's a clear sign that the glow plug is bad.
1/4" Quick Attach Blank Plate (A66408)
1/4" Quick Attach...
PORTER CABLE AIR COMPRESSOR (A65643)
PORTER CABLE AIR...
2011 Ford F-350 Crew Cab Service Truck 4x4 (A62613)
2011 Ford F-350...
2020 KENWORTH T880 DUMP TRUCK (A65054)
2020 KENWORTH T880...
Dirt Dog 3PBU Hay Unroller (A65579)
Dirt Dog 3PBU Hay...
Wolverine TL-12-72W 72" Skid Steer Tiller (A62679)
Wolverine...
