Ratchet Strap Tie Downs
/ Ratchet Strap Tie Downs #21
I use those $4 ones to keep stuff from blowing out of my pickup. I won't actually tie anything down with them.
/ Ratchet Strap Tie Downs #22
I've towed trailers with cars on/in them all over the East Coast using straps. Never had an issue loosening or stretching. These are not the straps you'd buy in TSC, which are very thin and almost plastic looking. These are a very fine weave, approx 1/4 inch thick, 3-4 inches wide strap, made for trailering. Not cheap either.
If straps are no good, why is it that truckers use them to secure their open loads ? Their trailers are even made with places to mount the strap hooks.
Towed a lot of Blue Ribbon show cars and we all use ratchet straps in all manor or configuration.
Chains are something used by wreckers and heavy equipment haulers...
I buy all my tie down equipment from
Mac's Package Deals: Tie downs, ratchet straps and axle straps
Made in USA... damage free towing... and great service...
/ Ratchet Strap Tie Downs #23
Someone earlier here said they never seen any commercial hauler carrying wheeled equipment using straps ?? Hmm , Guess they need to look at the rolling parking lots a little closer . Just this past week I seen 3 different haulers with 3 different technique's for holding cargo . 1 had all 4 wheels strapped , 2nd had only the front wheels strapped , third had right front and left rear strapped . All were using the over the wheel type straps , which Yes , are different than ratchet straps , but are still straps .
Fred H.
/ Ratchet Strap Tie Downs #24
I use both chains and straps. My straps come from Mac's. The heaviest load I haul is my B2620-with all attachments probably no more than 3500 lbs total. I use a chain and binder on the back, and 2 ratchet straps on the front.
My brother is an excavator. He uses a 3/8" chain and binder at each corner, and a 5/16" chain over the blade, bucket, or hoe.
Will
/ Ratchet Strap Tie Downs #25
We all agree, straps for light loads, chains for heavy loads... and check straps often, particularly if it is raing. Don't trust lightweight ratchets, frayed stap or use straps on sharp material...or big pipes.
/ Ratchet Strap Tie Downs #26
/ Ratchet Strap Tie Downs #27
Don't know if you guys have ever noticed, but 18-wheeler flat bed trailers generally have strap ratchets built into the trailer frame. Straps are standard practice for most of their freight loads.
/ Ratchet Strap Tie Downs #28
As I mentioned in post #10. It apparently doesn't make any difference to some posters.
/ Ratchet Strap Tie Downs #29
Saw a couple loads of steel today, a set of rolls of steel wire and a bunch of 2" solid bars.
All tied down with straps on 48' flatbed trailers.
Aaron Z
/ Ratchet Strap Tie Downs #30
Good onya pal..but you ain't gonna haul my frieght
What do you use to haul 100k plus collector vehicles?
One scratch and you're working for nothing.
I know I would have been shot chaining down a Ford GT...
FedEx transports a lot of high end cars the the drivers are experts with straps.
The moral is use the appropriate method for the load.
/ Ratchet Strap Tie Downs #31
It is the standard "Only my way is the right way"
LOL, back when, I was certified by the material handling association as to how to load cargo on flat cars down to using fork lifts and packing fragile products.
It is like anything, there are rules and regs specs etc and more so you are needing a certificate to do anything. Logic no longer is valid.
/ Ratchet Strap Tie Downs #32
I see nothing wrong with using straps if used correctly, tensioned correctly, protected from sharp corners and of the right rating for the equipment weight. I use chains and binders for my tractors mainly because there is really no place to tie off that doesn't have at least one sharp edge. I am not worried about knocking off a little paint if it happens. It is lots easier to spray some more black or orange paint than to pick up pieces if it comes off. A big plus is that it is much easier to determine if a chain is still good vs a strap that can look good but have chemical damage, sunlight damage, fraying etc that makes it useless. I have some 5000# rated straps that I use to anchor the FEL / backhoe but the chains and binders anchor the main load (tractor).
The problem with straps is that they do wear out rather fast, should be replaced at least every 5 years (or less if manufacturer requires it) regardless of wear and the heavy duty ones are not cheap.
/ Ratchet Strap Tie Downs #34
bcp,
Thanks for those FMCSA links!
In the link pertaining to <10K# loads, it states:
Securement requirement
- Use at least two tiedowns at both the front and rear of the cargo to prevent movement.
-- Side-to-side
-- Forward and rearward
-- Vertically
So,,,, the way I read that is that they want a chain and/or strap at all four corners - two in the front and two in the back. Fine, I get that.
Now, sometimes I've seen these four tiedowns crossed - like in an X - and other times they are simply direct, corner tiedowns and do NOT cross each other.
Is there a reason for these two ways of tiedown configuration?
BarnieTrk
/ Ratchet Strap Tie Downs #35
crossing the straps on either end help keep the vehicle from moving side ways.
/ Ratchet Strap Tie Downs #36
Personal taste and tiedown angles? Ideally, you want 45 degrees front to back and 45 degrees side to side.
Sometimes, the angles (to clear obstructions) work better crossing to the other side vs going to the the same side.
Aaron Z
2003 CASE 590 SUPER M SERIES 2 BACKHOE (A65053)
2003 CASE 590...
JOHN DEERE 7410 TRACTOR (A64278)
JOHN DEERE 7410...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
2017 Ford F-550 Altec AT40G 40ft. Insulated Bucket Truck (A64556)
2017 Ford F-550...
2012 POLAR TANK TRAILER (A63569)
2012 POLAR TANK...
2016 Peterbilt 579 Wet Kit T/A Day Cab Truck Tractor (A64556)
2016 Peterbilt 579...
