Rake of some sort
   / Rake of some sort #1
swick1
Platinum Member
WV
John Deere 1026R
I think I would like to build a rake for my front end loader. I want to use it for tearing out undergrowth like a ratchet rake and for smoothing dirt / pulling out small rocks to plant grass. I would also like to use it to gather sticks from what blows out of the trees around my property. What is the difference between uses for the following implements?
1. landscape rake / york rake
2. powered landscape rake / harley rake
3. ratchet rake
4. eliminator rake from loegering
I can see how a landscape rake would be good for turning rocks over and sorting them from dirt. I can also see how it would smooth a driveway, but I don't understand how it's better than a ratchet rake or eliminator rake. To me, the springy tines just look like an old design that's not as useful as new designs. What am I missing? I've never used one.
The harley rakes seem to do a great job, but I don't know how well they will windrow the rocks since they seem to only be mounted straight-on. I have remotes on the front of my loader, so I may be able to run one, but I don't know if the complexity is worth it. A tiller or pulverizer seems like it would do just as well without the flow requirements or extra complexity. I feel like this overlaps too much with a tiller to consider.
The ratchet rake seems great, but I don't want it to strap onto the bucket. I want mine to pin on / off or be its own attachment since I have a quick disconnect bucket. I may build this as an add-on to my grapple since it's mostly used for land clearing anyway.
The eliminator rake looks like a combination ratchet rake and pulverizer. This may be what i'm looking for rather than the traditional landscape rake. There's also a TR3 rake on youtube that looks very similar. Any suggestions?
I already have a rear scraper blade and a root grapple. I want this to mount on the loader because I have a backhoe that's always attached to the tractor and it's quicker to swap loader buckets than rear hitches.
   / Rake of some sort #2
I simply back drag with my tooth bar.
Changing the angle makes the action more or less aggressive as needed.
Near vertical and I have a very effective root puller.
   / Rake of some sort #3
I built a pond rake using heavy pipe and 3/4" cold rolled steel. The old desk top was to keep the vines from hanging over the rake. Works well but wouldn't be strong enough for the "power down" you get with a FEL.
   / Rake of some sort
That's wild looking!
   / Rake of some sort #5
when I fist saw the picture I thought you may want to invest in something that would cut pipe until i saw a pond rake, very nice
   / Rake of some sort #6
Harley Rakes work great. Just fork up 5k+ and get busy. Just kidding. Strapping on a Ratchet Rake takes only a few seconds longer than undoing a quick attach. It works much better than a toothbar. That's why the guy designed and built it!
The teeth on the Eliminator Rake look pretty wimpy and if you have a box blade you already have scarifiers.
   / Rake of some sort
Will Harley rakes tear out brush or does it all get wound up around the drum? I could build one for my 3 point hitch for $1000-$1300 easily.
I know they look like mulchers but I don't plan on shredding with it, just running over some bushes and grass.
Fel is possible too but I'd probably need a mid pro hydraulic pump to get the flowrate I need. Probably 15-17gpm at 2500psi given my 26hp engine.
   / Rake of some sort #8
They're really not designed for brush, but it depends on how tall the brush is. Power rakes process sod, grass and other organic material pretty good. It helps to scarify first if the ground is hard. Instead of windrowing material I typically just push it all to one end and then go back with the bucket to collect.
Can you brush hog first?
   / Rake of some sort
I don't think so. I could ratchet rake first though. I'm just brainstorming now though so any idea would be welcomed. My goal is to leave the hoe attached if possible so that reduces my desire to use a brush hog.
How about this question... what would make a ratchet rake better? I may just make it attach to my grapple unless I can make it a better standalone attachment. What are the shortcomings of a ratchet rake.
   / Rake of some sort #10
JWMORRIS if you ever make a YOUTUBE video
of your invention working I would love to see it.
Looks like it would work well.
2008 CATERPILLAR 304C CR EXCAVATOR (A51242)
2008 CATERPILLAR...
CHALLENGER VACUUM PUMPS (3) (A50854)
CHALLENGER VACUUM...
2008 RIB 24 Cat Boat (A50324)
2008 RIB 24 Cat...
1268 (A50490)
1268 (A50490)
2011 Nissan Titan SV 4x4 Crew Cab Pickup Truck (A50323)
2011 Nissan Titan...
2016 Big Tex 14ft. T/A Hydraulic Dump Trailer (A50322)
2016 Big Tex 14ft...
