radiant heat question in slab
   / radiant heat question in slab #31
</font><font color="blue" class="small">( <font color="red">I read not to put near toilet, the heat will melt the wax donut</font>
Fernco now makes a rubber gasket that glues to the toilet bottom & is a snug fit into the toilet flange eliminating the wax ring. made specifically for heated floors. Found it at Home Depot with the wax rings. I'll never use a wax ring again. )</font>
While I might agree that the rubber gasket may be better than the wax ring, I really don't think the floor will melt it. I have radiant heat in every room except our carpetted bedrooms (3) and the loft. My basement has it as well. Our 2 bathrooms have wax rings with no problems. The floors in those bathrooms are tile. They are never "hot"; they just don't feel cold to the touch so they have to be around +/- body temperature. I'm thinking if you hold a wax ring in your hand it wouldn't melt so it probably isn't as much of an issue as some people might think... Just my $.02...
For the basement we used one sheet of mesh, 6 x 6 with the tubing tied to it. When the cement was poured, we "hooked" the mesh to pull it up into the cement. It works good! Counting our basement, we heat over 3700 square feet and we average a little under 100 gallons of oil/month. My wife keeps the house at 72 degrees all winter and the oil heats our water as well. Many new homes in our area use that much oil and heat a significant amout less of square footage...
   / radiant heat question in slab #32
   / radiant heat question in slab #33
I put radiant heat in the garage. It was assembled in the following layers.
1. 4" 3/4" stone
2. Vapor barrier
3. 2" rigid insulation taped together
4. Vapor barrier
5. Wire mesh
6. 2 loops PEX tubing zip tied to wire mesh
7. Wire mesh with zip ties to the first wire mesh
The concrete has yet to crack after almost 10 years and there are no moisture issues.
   / radiant heat question in slab #34
1. 4" 3/4" stone
2. Vapor barrier
4. Vapor barrier
5. Wire mesh
   / radiant heat question in slab #35
Looks like a good system, except I agree with the comment on the bricks. I have purchased concrete bricks and broken in 1/2 and used them to prop up the rebar -- these bricks are the same size as standard clay bricks just poured out of concrete.
I don't like the wire mesh (nor does my slab contractor) since it gets stepped on when the concrete is being worked on.
An alternative that is easier is to use 3/8" (#3) rebar 18" on center in a mesh pattern and just use 7" plastic zip ties to tie it off. I find that if I use 1/2" pex and run it along side the rebar that I get just about the right amount of BTU transfer for the application. To get enough concrete coverage, you'll need to plan on at least a 5" thick slab (so that you get 2" below and above the rebar/tubing system). But you'll have a strong slab that you can park a tractor on top of.
   / radiant heat question in slab #36
2018 HINO 268 24FT NON CDL REEFER BOX TRUCK (A59575)
2018 HINO 268 24FT...
PALLET OF 15 4X8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4X8...
Caterpillar 262C Compact Wheel Loader Skid Steer (A59228)
Caterpillar 262C...
44052 (A55852)
44052 (A55852)
New/Unused Quick Attach Bale Spear (A57454)
New/Unused Quick...
2025 Stump/ Trench Bucket Mini Skid Steer Attachment (A56857)
2025 Stump/ Trench...
