Quick Trailer Jack Question
/ Quick Trailer Jack Question #1
Iplayfarmer
Super Member
Idaho
Massey Ferguson 1215, Case 801B
When a jack is rated at 3500 pounds does that mean the jack will hold 3500 pounds or that the jack is meant to go on a trailer rated at 3500 pounds?
/ Quick Trailer Jack Question #2
/ Quick Trailer Jack Question #4
I'd have to agree.. I believe if you buy a jack with a weight rating.. that is the jack max weight rating.. not the size class trialer it will go on.
soundguy
soundguy
Congrats on being Member of the Month. I knew it would come around to you sooner vs. later.
/ Quick Trailer Jack Question #6
mine was a while back, but thanks.
there are some many good people here, I love to see the beginning of the month anouncements to see who is featured next.
soundguy
That explains why it says "April 2010" after member of the month.
Congratulations anyway. I know you've helped me more than once. There are a lot of good people here with a lot of good experience and advice.
/ Quick Trailer Jack Question #8
Since were on the subject, I bought a used trailer and the trailer jack is pretty rusted. Takes two men and horse to crank the thing. If it was bolted on I would just put a new one on, but it's welded. Is there something I can do the get if free'd up.
Wedge
/ Quick Trailer Jack Question #9
Where the crank handle goes in at the top should be a felt or rubber seal.. most of the time it wears. get some penetrant oil like PB blaster or liquid wrench and spray in there using the straw.. usually it will puddle then drian, then hit it with some more till it has taken quite a bit.
get the trailer supported on something so you can run the jack up and down without it bearing weight.
keep oiling and working it. if you don't have penetrant oil, but do have a squirt bottle, some atf fluid mixed with your choice of the following solvents will work:
diesel, kerosene, mineral spirits or naptha
acetone - be carefull.. not my first choice.. but will work.. can eat some rubber, and not nice on the eyes. diesel is my first choice due to cost.
use that in a squirt bottle and work her out. too bad most of them dont have grease fittings..
post back.
soundguy
/ Quick Trailer Jack Question #10
Thanks. It wont be till this weekend. I refuse to work outside when it's above 90 degrees. I have diesel, just need to pick up some atf. Also have a few can of PB blaster.
Will the foot pull all the way out. If os I'd be temped to put a grease zerk on once I get it free'd up.
Wedge
/ Quick Trailer Jack Question #11
I had a similar problem and after fooling around with it for way too long, I cut off the old one, drilled three holes and bolted on a new one.
/ Quick Trailer Jack Question #12
none of mine will screw all the way out. not saing yours won't though.
if you have pb oil.. work with that.. no need to buy anything.
once you get it freed up. if there is an opening at the top big enough for an oil can, give it a squirt of some kind of oil each time you use it. engine, tranny, rear end.. etc. pretty much won't matter..
soundguy
/ Quick Trailer Jack Question #13
On my trailer jacks the top cap just pops right off letting you see all the good stuff inside. :D
2012 Ford Explorer SUV (A61574)
2012 Ford Explorer...
CHEVY 4X4 DUALLY TRUCK BED (A65643)
CHEVY 4X4 DUALLY...
2000 FORD F-550 XL SUPER DUTY DUALLY SERVICE TRUCK (A60430)
2000 FORD F-550 XL...
2022 FORD TRANSIT 250 CARGO VAN (A59905)
2022 FORD TRANSIT...
2016 Ford Explorer AWD SUV (A61574)
2016 Ford Explorer...
2011 PETERBILT 367 (INOPERABLE) (A65643)
2011 PETERBILT 367...
