Quick Hitches quick hitch problems
/ quick hitch problems
If you had the qh working would that help your hose promblem?
/ quick hitch problems #62
Unfortunately no. I'm having a clearance issue back where the top-link attaches to the tractor.
After having all of these problems with the harbor freight quick hitch I got disgusted and threw it away. I went the Kubota dealer to see what kind of quick hitches he had. He had just got some new ones in, I was the first person he sold one to.;) Here is a picture of it.
/ quick hitch problems #64
How is it different from the HF one, other than the color?
Bruce
Bruce
Its the same I was just joking. I added the decals to it.
/ quick hitch problems #66
I bought a 1.5 inch steel shaft and cut it in 2 inch pieces then drilled a 7/8 hole in the center and had enought for all my equipment for $8.00 < Kubota BX2660>
/ quick hitch problems #67
I finally got caught up on projects and had some time today to get back to the Quick Hitch. I think I have it working with my blade. The problem seemed to be that the two plates on the quick hitch where the top hook mounts were spread too far apart. To make matters worse the side plates appeared to be flared slightly, making the problem worse. I took a two pronged approach to solving the problem. I put two washers on either side of my rear blade which opened up the hook channel about 1/8". I also bent the two hook mounting plates in a bit on the quick hitch and took out some of the flare. The top hook now fits better in the channel.
I mounted and dismounted the blade several times and it seems to be working much better. I'm not sure if my top link bushing is still correct. It still has a fair amount of slop in the hook. I'm currently using a Cat2-Cat1 bushing from Tractor Supply (#268446).
Below are some photos to show how things look after my modifications. Thanks again to everyone on this forum for your help.
View attachment 280963 View attachment 280964 View attachment 280965
View attachment 280966 View attachment 280967
You will also need a cat 2-cat3 bushing for the qh. When you use a qh it changes everything to cat 3.
/ quick hitch problems #69
I used two bushing (1-2 & 2-3) for each pin on my HF hitch.
Bruce
/ quick hitch problems #70
Thanks guys, very helpful.
I just purchased a JD Cat 2 quick hitch its a monster, very well built. But I notice that the dog that attaches to one of the lock handles is stuck open. I can
close it by taking off the back plate and beating it with a hammer, but thats no good. Any idea what might be wrong? Is their a bent shaft or pin inside?
Looks like a good bit of work to take it apart.
Any suggestions?
Craig
/ quick hitch problems #71
This has been a popular gripe for several years, many past posts on this subject including my detailed ones. I have not read past the first page as it is now old hat. Bottom line you have to extend the hook, bore out the frame at the bottom for 7/8 pins, and grind 3/16" off each side of the bottom Hooks. For the right bushings got to a Land Pride Dealer and order what you need. Their implement manuals are free on line and have part numbers for then bushings of various lengths. Get longer ones and cut off if needed. I tried to find bushing stock but could not match any thing up. I still saved $200.
Ron
Any suggestions?
Craig
Do you have a picture of it, I don't understand completely what is wrong.
/ quick hitch problems #74
Yes, I understand. Here is a picture of the lower arm of the JD Quick Hitch. The problem is with the "dog" or latch plate does not slid forward to catch or lock the implement on to the quick hitch. The latch seems to be bound or twisted inside the housing. The only way I can get it to function is to beat on it from the back side with a hammer. Once it is in place on the implements lower 3 point hitch arm it will not release, unless by driving it back with a hammer. So I just to check to see if others have similar problems and what was done to correct it.
Thanks,
CraigView attachment 394274
Thanks,
The picture is not working. I think I understand now though. It sounds like the latch is binding. It does sound like something could be bent inside. Can you look up through the bottom of the quick hitch and see anything?
/ quick hitch problems #76
Yes, probably binding. I did take over the cover on the back of lower arm. Nothing appears to be wrong. I guess i will have to try drive out the pin that the latch pivots on. That should give clear access to the problem. Probably something bent out of place.
Any other suggestions?
Thanks,
Craig
Wooden Side Table (A61569)
Wooden Side Table...
2006 International 7500 Asphalt Truck, VIN # 1HTWNAZTX6J383773 (A61165)
2006 International...
New/Unused Electric Golf Cart (A61166)
New/Unused...
UNUSED KJ 20' BI-PARTING GALVANIZED GATE (A62131)
UNUSED KJ 20'...
Kubota RTV X1140 (A60462)
Kubota RTV X1140...
2007 Chevrolet Express Shuttle Bus (A61568)
2007 Chevrolet...
