Quick connect fittings leaking
   / Quick connect fittings leaking #1
rob in ore
Western Oregon
Kubota B2320
The fittings that supply the backhoe (Woods BH77, dealer installed about 8 years ago), have started to leak a little more than I'm comfortable with. The leak is most noticeable when the backhoe is removed and the supply/return lines are plugged into each other. These hoses and fittings are only used for the backhoe. They are only connected/reconnected three or four times a year.
Could the fittings be worn out with such light usage? Is there something else I should look for? The hoses and threaded connections are dry.
Can I just change the fittings on the tractor or should I change the mating set on the backhoe at the same time?
The real culprit turned out to be one of the crimped connections. I guess they weren't as dry as I thought.
I replaced the o-ring. Thank you for that, I didn't know there was such a thing in there.
When the leaked returned, I wiped it all down again and was able to see it while working the control lever. A new hose and it's fixed.
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52141)
2016 FREIGHTLINER...
2019 CATERPILLAR 259D SKID STEER (A51242)
2019 CATERPILLAR...
2006 BOMAG BW5AS DOUBLE DRUM COMPACTOR (A51242)
2006 BOMAG BW5AS...
John Deere 1110 Field Cultivator - Heavy-Duty Soil Finisher for Precision Tillage (A52128)
John Deere 1110...
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2018 GENIE...
2003 International 4300 Flatbed Truck w/ Liftgate - Inoperable - 7.6L DT466 Diesel Engine (A52128)
2003 International...
